I just built a new computer. I'm running Ubuntu 18.04, and I'm not dual-booting.
Ubuntu is installed on my SSD, but I'd like to also use an internal HDD (connected via SATA to my motherboard) for additional storage. I've been following this set of instructions to set things up. The HDD is formatted as ext4 and automatically mounts at boot, but that's as far as I've got. I'm stuck on Step 4, moving folders from ~/home/ to the HDD and making symbolic links.
I can't drag folders from Home to the mounted HDD via the file explorer. I also cannot create new directories in the mounted HDD via the file explorer. When I check the permissions of the mounted HDD (via right-click->Properties->Permissions), it says "The permissions of 'drivename' could not be determined."
From doing some further research, I suspect this is a permissions issue; however, I have been unable to determine what specifically I need to do. How do I troubleshoot this and write to my internal HDD?
Edit: The contents of my /etc/fstab file are as follows:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sdb1 during installation
UUID=b928c257-beab-4352-81d0-9ae12955bf96 / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/sdb3 during installation
UUID=5B6B-1052 /boot/efi vfat umask=0077 0 1
# /home was on /dev/sdb4 during installation
UUID=8d372b78-f15c-4c85-b853-becfafa28d69 /home ext4 defaults 0 2
# swap was on /dev/sdb2 during installation
UUID=1972e189-a0fe-448d-93db-c17028c913c8 none swap sw 0 0
/dev/disk/by-uuid/c0c74b6f-dedb-4a3e-b5d8-52cca8a0958e /mnt/stuff auto nosuid,nodev,nofail,x-gvfs-show,x-gvfs-name=Stuff 0 0
Edit 2: Here's the relevant entry from running lsblk -fm -e 7:
sda ext4 c0c74b6f-dedb-4a3e-b5d8-52cca8a0958e /mnt/stuff 1.8T root disk brw-rw----
