I have a headless Ubuntu server install inside a VM, running on Hyper-V using lvm. I have full access to the VM, but no access to the Hyper-V environment (so can't boot with a LiveCD).
I need to expand my filesystem as I've already eexpanded my physical disk at the virtual level, but am having issues as sda1-5 are already in use.
Is there anything I can do to make use of the space assigned to the server but not used?
My mounted volumes:
root@SRVLIN01:~# mount | grep --regexp "^//[0-9]" --regexp "^/dev"
/dev/mapper/SRVLIN01--vg-root on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
/dev/sda1 on /boot type ext2 (rw,relatime,block_validity,barrier,user_xattr,acl,stripe=4)
root@SRVLIN01:~#
My logical volumes:
root@SRVLIN01:~# lvdisplay --maps
  --- Logical volume ---
  LV Path                /dev/SRVLIN01-vg/root
  LV Name                root
  VG Name                SRVLIN01-vg
  LV UUID                0GWjvA-b7H7-nLqX-TOtV-VNdR-QFT3-nhucpd
  LV Write Access        read/write
  LV Creation host, time SRVLIN01, 2017-05-04 09:40:59 +0100
  LV Status              available
  # open                 1
  LV Size                117.51 GiB
  Current LE             30083
  Segments               3
  Allocation             inherit
  Read ahead sectors     auto
  - currently set to     256
  Block device           252:0
  --- Segments ---
  Logical extents 0 to 14722:
    Type                linear
    Physical volume     /dev/sda5
    Physical extents    0 to 14722
  Logical extents 14723 to 14725:
    Type                linear
    Physical extents    15234 to 15236
  Logical extents 14726 to 30082:
    Type                linear
    Physical volume     /dev/sda4
    Physical extents    0 to 15356
  LV Path                /dev/SRVLIN01-vg/swap_1
  LV Name                swap_1
  VG Name                SRVLIN01-vg
  LV UUID                KFFa26-3GQY-Fbc3-QIU2-BdRe-h7Af-s16fKE
  LV Status              available
  # open                 2
  LV Size                2.00 GiB
  Current LE             511
  Segments               1
  Allocation             inherit
  Block device           252:1
  --- Segments ---
  Logical extents 0 to 510:
    Type                linear
    Physical extents    14723 to 15233
My physical volumes:
root@SRVLIN01:~# pvdisplay
  --- Physical volume ---
  PV Name               /dev/sda5
  VG Name               SRVLIN01-vg
  PV Size               59.52 GiB / not usable 2.00 MiB
  Allocatable           yes (but full)
  PE Size               4.00 MiB
  Total PE              15237
  Free PE               0
  Allocated PE          15237
  PV UUID               ljFlcO-kfjd-bx2d-74DJ-BY3S-zoKM-dBmfiJ
  PV Name               /dev/sda4
  VG Name               SRVLIN01-vg
  PV Size               60.00 GiB / not usable 0
  Allocatable           yes
  PE Size               4.00 MiB
  Total PE              15360
  Free PE               3
  Allocated PE          15357
  PV UUID               WY90Op-u2Bz-nVTf-D2ed-q4Zu-lEgW-e4ZLfY
Fabby
  • 35,017
c-hri-s
  • 23
You are running in a Virtual Machine (VM) using lvm: Logical Volume Manager and the only unused physical partition not under its control is /dev/sda3 which is just 1MB, so that won't help you much.
lvm is really great at handling multiple kinds of storage and can combine multiple disks into one Physical Volume (PV) which can then be (re-)assigned as you need them.
However, you have allocated all (except 1MB) of your physical disks, so now you only have these choices:
  1. add another disk
    • Don't expand existing mounted disks that you cannot dismount to expand in the future.
    • never assign 100% of your disks so you can extend your existing Physical Volumes on the free space you now have with your new disk.
  2. Alternatively, mount a gparted live ISO from within grub if your Hyper-V environment gives you access to that.
    • Take a full snapshot of your VM!!!
    • Download the gparted live iso
    • copy it in /opt/LiveISOs
      sudo mkdir /opt/LiveISOs
      sudo cp ~/Downloads/gparted-live-1.0.0-3-amd64.iso /opt/LiveISOs
    • edit /etc/grub.d/40_custom to include the following at the end:
      menuentry "GParted Live ISO" {
        set ISOFile="/opt/Live-ISOs/gparted-live-1.0.0-3-amd64.iso"
        loopback loop ($root)$ISOFile
        linuxefi (loop)/live/vmlinuz boot=live components config findiso=$ISOFile ip=frommedia toram=filesystem.squashfs union=overlay username=user
        initrdefi (loop)/live/initrd.img
    • set grub's timeout parameter to anything but 0
    • update the grub config:
      sudo update-grub2
    • Reboot to grub
    • Take menu option GParted Live ISO
    VoilĂ : a virtual USB key has been inserted in your VM virtually and you can now shrink / expand partitions off-line using gparted or using lvm utilities from the command line!
#2 above will not work if the only thing you have is ssh access to your VM...
Fabby
  • 35,017
