I am trying to install libgeos-dev on ubuntu 16.04
This command
apt-get install libgeos-dev
get this error
# apt-get -f install libgeos-dev
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
cpp-5 : Depends: gcc-5-base (= 5.4.0-6ubuntu1~16.04.11) but 5.4.0-6ubuntu1~16.04.10 is to be installed
g++-5 : Depends: gcc-5-base (= 5.4.0-6ubuntu1~16.04.11) but 5.4.0-6ubuntu1~16.04.10 is to be installed
gcc-5 : Depends: gcc-5-base (= 5.4.0-6ubuntu1~16.04.11) but 5.4.0-6ubuntu1~16.04.10 is to be installed
gfortran-5 : Depends: gcc-5-base (= 5.4.0-6ubuntu1~16.04.11) but 5.4.0-6ubuntu1~16.04.10 is to be installed
apt-get install gcc-5=5.4.0-6ubuntu1~16.04.11 get the same error as above.
This command
# apt-get install gcc-5=5.4.0-6ubuntu1~16.04.11 \
> gcc-5-base=2.2.20-1ubuntu1~16.04.11
get this error
E: Version '2.2.20-1ubuntu1~16.04.11' for 'gcc-5-base' was not found
this question is different from that post
as I said previously, apt-get -f does not work, and I am work on a CLI server which does not have GUI.
how can I install the dependencies?
