I'm looking to take a whole system backup and store it on S3. Something that could be good enough to restore my entire system. But I've been told that using dd/rsync to capture the root directory will save a lot of extraneous files that I wouldn't need to restore the system.
In the event that I had to reply on this backup, I would need to restore:
  • The home directory
  • All installed programs
  • All customizations throughout the system, such as edits to the Openbox configuration file, etc
The command I see recommended here is:
sudo rsync -aAXv / --exclude={"/dev/*","/proc/*","/sys/*","/tmp/*","/run/*","/mnt/*","/media/*","/lost+found"} /mnt
Is it possible to go lighter than that?
Eliah Kagan
  • 119,640
You might look at a combination of Backups (Déjà Dup) for your /home, and Timeshift for the system stuff. Otherwise, use Macrium Reflect to clone your entire disk/partition.
The closest thing to a Windows-like restore point is by using Timeshift. I use it to save snapshots to an external USB hard drive. Although it can, it's normally not used for backing up your /home directory, just system-level changes. Use Backups (Déjà Dup) for backing up /home files.
Timeshift is a system restore utility which takes snapshots
of the system at regular intervals. These snapshots can be restored
at a later date to undo system changes. Creates incremental snapshots
using rsync or BTRFS snapshots using BTRFS tools.
More information at https://github.com/teejee2008/timeshift
For pre-19.04 users, add the PPA:
sudo add-apt-repository -y ppa:teejee2008/ppa
And install with:
sudo apt update
sudo apt install timeshift
Fabby
  • 35,017
heynnema
  • 73,649
From: Bash script to backkup/clone Ubuntu to another partition
rsync -haxAX --stats --delete --info=progress2 --info=name0 --inplace  \
      /* "$TargetMnt"                                                   \
      --exclude={/dev/*,/proc/*,/sys/*,/tmp/*,/run/*,/mnt/*,/media/*,/lost+found}
The script also updates /boot/grub/grub.cfg and /etc/fstab so you can boot your backup.
