Question relates to: Chromebook 15 Acer model CB3-532 Braswell
With write protect screw removed I performed full BIOS flash. Replaced write protect screw. Installed Ubuntu 18.04 as the only operating system.
Laptop is fully operation apart from sound which worked fine before BIOS flash.
I only get Dummy Output.
lspci
00:1b.0 Audio device: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio Controller (rev 35)
aplay -l
karta 1: chtrt5650 [chtrt5650], urządzenie 0: Audio (*) []
  Urządzenia podrzędne: 1/1
  Urządzenie podrzędne #0: subdevice #0
karta 1: chtrt5650 [chtrt5650], urządzenie 1: Deep-Buffer Audio (*) []
dmesg | grep -i snd
[    3.936277] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    4.444225] cht-bsw-rt5645 cht-bsw-rt5645: snd-soc-dummy-dai <-> media-cpu-dai mapping ok
[    4.444267] cht-bsw-rt5645 cht-bsw-rt5645: snd-soc-dummy-dai <-> deepbuffer-cpu-dai mapping ok
cat /proc/asound/cards
 0 [PCH            ]: HDA-Intel - HDA Intel PCH
                  HDA Intel PCH at 0xd1314000 irq 315
 1 [chtrt5650      ]: chtrt5650 - chtrt5650
                  GOOGLE-Banon-1.0-Banon
Tried so far:
1) set /etc/modprobe.d/alsa-base.conf to
options snd-hda-intel model=intel-x58
and
options snd-hda-intel model=auto
and
options snd-hda-intel model=acer
and
options snd-hda-intel model=generic
All options no sound. The last one actually showed HDMI/DisplayPort which might be avenue to follow but I do not know how?
2) sudo apt-get install oem-audio-hda-daily-dkms following sudo apt-add-repository ppa:ubuntu-audio-dev/alsa-daily
No change.
3) This seams related: https://github.com/GalliumOS/galliumos-braswell/blob/master/usr/share/alsa/ucm/chtrt5650/chtrt5650.conf This cards shows as 5650 or 5645 I am not sure what this means but following suggestion in the answer I tried:
3.1) downloaded files: github.com/GalliumOS/galliumos-braswell/blob/master/usr/share/… and github.com/GalliumOS/galliumos-braswell/blob/master/usr/share/…
3.2) put them as /usr/share/alsa/ucm/chtrt5650/chtrt5650.conf and /usr/share/alsa/ucm/chtrt5650/HiFi.conf (it was necessary to create chtrt5650 folder as it was not there before)
3.3) Rebooted and: No change. Dummy Output still as the only sound output device.
Try downloading that file and the HiFi.conf (https://github.com/GalliumOS/galliumos-braswell/blob/master/usr/share/alsa/ucm/chtrt5650/HiFi.conf) and put them in /usr/share/alsa/ucm/chtrt5650/chtrt5650.conf and /usr/share/alsa/ucm/chtrt5650/HiFi.conf
If you run sudo dmesg | grep audio and see direct firmware load failed error, then try manually copying sof-bin firmware to /lib/firmware/intel/sof-tplg/ folder. See instructions in the answer of no sound due to error direct firmware load failed for intel/sof-tplg/sof-byt-max98090.tplg
(I am not a developer, just a regular user who encountered a similar problem. )
J.T.
  • 397
