I'm unable to install on a couple of identical desktop PCs. They have identical specs, and both fail in similar ways so I believe its unlikely to be hardware failure. I've tried 19.04 and 18.04.2 LTS.
The installer fails from both Live USB boot and then install and from direct install from GRUB.
It fails due to random parts crashing at any point during the installer - the timezone picker crashes, the part which is making partitions fails, it fails with a random unknown error later in the process and tries to make an error report but crashes out completely during that phase. I can't get any debugging information out.
I've tried disabling UEFI Secure Boot from BIOS and have gone through looking for any weird looking power savingfeatures in BIOS but I'm not really sure I'm looking for? I've formatted the disks with long format i.e. writing 0s just to make sure no weird partition problems from all the failed install attempts.
I've also tried two different USB sticks.
Any advice for where to look for errors or what to try switching off? Here is the hardware spec. Again I have two identical PCs both with this issue.
Processor (CPU) IntelĀ® CoreTM i5 Six Core Processor i5-8500 (3.0GHz) 9MB Cache
Motherboard ASUSĀ® H310M-A R2.0: Micro-ATX, DDR4, LGA1151, USB 3.1, SATA 6GBs
Memory (RAM) 16GB Corsair VENGEANCE DDR4 2400MHz
Graphics Card 2GB NVIDIA GEFORCE GT 1030
Edit: After adding nomodeset to the boot parameters and installing with no graphics drivers it crashes and when attempting to create the installation error report. Ubiquity crashes stating the home partition has less than 0.0MB of free space. This is on an install specifying a fresh install on the entire 250GB SSD.
Is it possible some kind of error log is filling up the drive? Hard to see how you can generate 250GB of error within a few minutes though... I don't know how to read the error logs while installing. Can I drop an init level and cat the logs? I'm so lost... :(
Edit: Managed to drop an init level and see what's going on. The screen is having a lot of fun posting a LOT of errors cascading down the screen. Got a photo to read the errors: PCIe Bus Error: Secerity=Corrected type=Phsyical Layer... etc
Going to do some googling of this. Maybe this error is filling up the root partition
Edit: Added pci=nomsi to the boot parameters on grub led to a successful installation. Reference: PCIe Bus error severity=Corrected
This came about after using nomodeset parameter which let me see the logs filling up the hard drive.
I think there are still some underlying issues with either the CPU or the WiFi chip which is talked about in other discussions, leading to this error. As long as I can keep them suppressed from filling up the SSD I guess its okay...
Marogian
  • 149
Random crashes, i.e. hardware stability problems like this (which is what I gather from what you write is the issue here) can be related to hardware timing. Try resetting your system's BIOS setup to "safe" values. Most BIOS setup programs have either "fail-safe" factory defaults or a "safe" set of pre-set values. If that doesn't work, your hardware is the most likely culprit. Some Asian hardware manufacturers cut corners in a major way, but in such a way that Windows still runs most of the time, and that's all they care about.
After help I discovered the underlying issue was caused by my log files being flooded with errors caused by some problems with CPU or WiFi chip architecture.
This is suppressed on install by editing the GRUB settings on install:
On the grub screen press "E" to edit the boot command and add pci=nomsi after quiet splash
After successful install I cat'd /var/log/kern.log and verified the error was still flooding in on a real install, so to add this parameter permanently to grub:
sudo nano /etc/default/grub
And add pci=nomsi parameter to the file like:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pci=nomsi"
Save the file and then run sudo update-grub and reboot.
Not ideal but it seems to be working for now...
Marogian
  • 149
