For some file sharing I had to install X2Go Client, which removed some packages. I think it also removed ubuntu-desktop packages, since I cannot find the file explorer and libre office anymore.
I'm trying to reinstall these packages by running sudo apt install ubuntu-desktop, resulting in
ubuntu-desktop : Depends: nautilus but it is not going to be installed
Recommends: libreoffice-calc but it is not going to be installed
Recommends: libreoffice-gnome but it is not going to be installed
Recommends: libreoffice-impress but it is not going to be installed
Recommends: libreoffice-math but it is not going to be installed
Recommends: libreoffice-ogltrans but it is not going to be installed
Recommends: libreoffice-writer but it is not going to be installed
Recommends: nautilus-share but it is not going to be installed
Output of apt-cache policy nautilus ubuntu-desktop:
nautilus:
Installed: (none)
Candidate: 1:3.26.3-0ubuntu4
Verstion table:
1:3.26.4-0~ubuntu18.04.4 -1
100 /var/lib/dpkg/status
1:3.26.3-0ubuntu4 500
500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages
ubuntu-desktop:
Installed: (none)
Candidate: 1.417
Version table:
1.417 500
Installing separate packages (nautilus, libreoffice) also results in similar errors. Actions taken so far:
- Use aptitude for installation
- Remove X2Go Client before installation
- First run
sudo apt install -f - First run
sudo apt --fix-broken install - Run
sudo apt install --reinstall ubuntu-desktop - Run
sudo dpkg --configure -a && sudo apt autoremove -y && sudo apt autoclean && sudo apt remove && sudo apt clean && sudo apt update && sudo apt install -f && sudo apt full-upgrade -y
Using Ubuntu 18.04.2 LTS
