Does Ubuntu update software packages like KeePassXC in LTS versions or does LTS mean I keep the version that was current when the LTS was released?
I installed KeePassXC on Ubuntu 18.04 LTS. I don't recall now what version of KeePassXC it was when I first installed it, but as of today it's 2.3.1. The most up-to-date version is now 2.4.1. I understand I can get updates by Snap and PPA, but I'm curious if a normal Ubuntu software update will eventually update KeePassXC or whether it remains static throughout the LTS period.
Edited to add: I understand now from the responses that the software packages were frozen to the time of release and that normally they will remain static and not be updated with the normal "Check for software updates." Does this static approach hold true for "apt-get"-type approaches, or can I get updates that way, eventually? I note from the source code link that KeePassXC 2.3.1 is still the source, but don't understand if I can "force" an update outside of Snap or PPA.
Further edited as possible duplicate: The basic question was essentially a duplicate, but my first edit took it further - "as the repositories change, can I then "apt-get" an updated version. It appears the answer is "no, not safely."
JWNWSA
  • 167
Unfortunately, Ubuntu does not always provide the latest version of a software. And the latest version of the software provided depends on the Ubuntu version you are using. This is for stability of each specific Ubuntu version. One exception may be the web browser (e.g. Firefox) since it is critical from security point of view.
In your case you can look at the following:
https://packages.ubuntu.com/search?keywords=keepassxc
A more detailed explanation was given in a similar Ask Ubuntu question.
FedKad
  • 13,420
The KeePassXC download page provides a PPA:
https://launchpad.net/~phoerious/+archive/ubuntu/keepassxc
You can find a lot of information about "What are PPAs and How do I use them?", but PPAs allows for someone other than Ubuntu to maintain and publish a package, and for your system to take in these updates when they are available.
This means that the software you're asking about, KeePassXC, is maintained by KeePassXC, not Ubuntu, and you'll have to ask them or look at their history and policies to determine their release schedule and planning.
When you upgrade Ubuntu, say from 16.04 to 18.04, all of these PPAs are disabled, and you will need to re-enable them. Until you re-enable them, they will not and cannot update. Most times you can just re-enable them. Sometimes you need to follow new setup instructions.
To best answer your question, you should check out the KeePassXC download page and see what they are claiming to be the latest version (which it seems you have) and compare that to the results of apt search keepassxc. You can check the KeePassXC PPA and confirm your apt has the latest available version by comparing the results to the PPA page.
At this time, the PPA page matches the KeePassXC download page latest version:
keepassxc   2.4.1-1ppa1~bionic1
If you do not see this version, you have outdated packages (apt update), no longer have this PPA enabled, or some other issue. It seems that the latest version of KeePassXC is available in the PPA at this time.
earthmeLon
  • 11,658
