Sorry, I have to revisit this. All the methods recommended have not worked for me. I am unsure where my error is after multiple attempts.
I have a Griffin Powemate that I use as an external volume control (don't judge me). I want it to work after resuming from Standby/ Sleep. As it is now, I have to run a script from the command line to get it to to re-start. I am using Ubuntu 16.04 with Cinnamon Desktop
The Powermate will activate and control volume if I run any of these commands from the command line - if the machine is in sleep/standby
pmlogin.sh
/usr/local/bin/powermate
evrouter -c /etc/evrouterrc /dev/powermate
powermate
If I re-power the machine, it only works if I run "pmlogin.sh"
The scripts are:
/home/mspringer/bin/pmlogin.sh
    #!/bin/sh
    rm /tmp/.evrouter:0
    #!/bin/sh
contents of /etc/evrouterrc:
Window ""
    "Griffin PowerMate" "" any key/256 "XKey/XF86AudioMute"
    "Griffin PowerMate" "" any rel/7/1 "XKey/XF86AudioRaiseVolume"
    "Griffin PowerMate" "" any rel/7/-1 "XKey/XF86AudioLowerVolume"
/dev/powermate is a link to /dev/input/event12 - the input from the Griffin Powermate.
The "/usr/local/bin/powermate" script is from the instructions I found to make it work. The pmlogin.sh was written by me because I had problems with the original script running after resume due to the existence of the /tmp/.evrouter:0 file.
I have followed every instruction that I could find, none of the methods have worked for me so far. Could someone please tell me what I am doing wrong or what will work? Just an FYI, I am not a total noob, I currently run/ maintain about 5 different Ubuntu installations and have been able to solve any problem I have had. This one I cannot resolve.
These are the basic methods I have followed, other links point me back to one or the other of these.
how to execute a command after resume from suspend? Make a script start after suspend in Ubuntu 15.04 (systemd) Run Script on Wakeup? How to run a script when suspending/resuming? - Sony VAIO Ubuntu 12.04
dessert
  • 40,956
kellyvotrenom
  • 189
