I am trying to install R on an Ubuntu 18.04 machine and am encountering an "unmet dependencies" problem. However, I am unable to determine where I can go or what I need to fix on my system to overcome this. Any help would be greatly appreciated.
I am running Ubuntu 18.04.2 LTS (with 16Gb RAM and 500Gb hard disk), using just the standard bionic repositories; the only PPA i've added is that for libreoffice. To see what's there, the output to sudo apt update is
Ign:1 http://dl.google.com/linux/chrome-remote-desktop/deb stable InRelease
Ign:2 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:3 http://dl.google.com/linux/chrome-remote-desktop/deb stable Release
Hit:4 http://dl.google.com/linux/chrome/deb stable Release
Get:7 https://desktop-download.mendeley.com/download/apt stable InRelease [2,456 B]
Get:8 https://typora.io/linux ./ InRelease [758 B]
Hit:9 http://repository.spotify.com stable InRelease
Hit:10 https://cloud.r-project.org/bin/linux/ubuntu bionic-cran35/ InRelease
Hit:11 http://ppa.launchpad.net/libreoffice/ppa/ubuntu bionic InRelease
Hit:12 http://sg.archive.ubuntu.com/ubuntu bionic InRelease
Hit:13 http://sg.archive.ubuntu.com/ubuntu bionic-backports InRelease
Get:14 http://sg.archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Fetched 91.9 kB in 3s (26.5 kB/s)
Reading package lists... Done
Building dependency tree
All packages are up to date.
(I try to keep things in sync as much as possible and run sudo apt update && sudo apt upgrade at least once every two days.)
When I attempt to install the first of R's components r-base (via sudo apt install r-base) I get the following unmet dependencies:
 r-base : Depends: r-base-core (>= 3.4.4-1ubuntu1) but it is not going to be installed
          Depends: r-recommended (= 3.4.4-1ubuntu1) but it is not going to be installed
          Recommends: r-base-html but it is not going to be installed
Running software-properties-gtk, I see that all repositories are enabled. Running sudo apt-get clean and sudo apt-get autoclean proceeds to completion with no error messages. When I execute
$ sudo apt-get -f install
$ sudo dpkg --configure -a
the output is
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
so there seems to be no held or conflicted or broken packages on my system. I have also executed sudo apt --fix-broken install, but again, as above, my system seems to have no held or broken packages.
Running sudo apt-get dist-upgrade shows
Calculating upgrade... Done
I'm happy to try anything else someone might want to suggest to see if the fault remains on my system.
Next I add
deb https://cloud.r-project.org/bin/linux/ubuntu bionic-cran35/
to my /etc/apt/sources.list and run
$ sudo apt update
$ sudo apt install r-base
Still no joy; the output is now (omitting repeats from above)
 r-base : Depends: r-base-core (>= 3.6.0-2bionic) but it is not going to be installed
          Depends: r-recommended (= 3.6.0-2bionic) but it is not going to be installed
(but at least I've moved from 3.4.4-1ubuntu1 to 3.6.0-2bionic.) Repeating the sudo apt-get -f install ; sudo dpkg --configure -a; sudo apt-get -f install sequence above continues to show
so again there seems to be no held or conflicted packages otherwise.
The output from apt-cache policy r-base is:
  Installed: (none)
  Candidate: 3.6.0-2bionic
  Version table:
     3.6.0-2bionic 500
        500 https://cloud.r-project.org/bin/linux/ubuntu bionic-cran35/ Packages
     3.6.0-1bionic 500
     3.5.3-1bionic 500
     3.5.2-1bionic 500
     3.5.1-2bionic 500
     3.5.1-1bionic 500
     3.5.0-1bionic 500
     3.4.4-1ubuntu1 500
        500 http://sg.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
        500 http://sg.archive.ubuntu.com/ubuntu bionic/universe i386 Packages
I'm not sure, however, where to go dig further or what files to adjust based on this output.
Are there locations I need to add to my /etc/apt/sources.list to put in place the dependencies on r-base-core and r-recommended? Where else do I need to go to get them? The linux installation page
https://cran.ma.imperial.ac.uk/bin/linux/ubuntu/README.html
does not suggest to me anything further to add to my /etc/apt/sources.list. Google returns a whole bunch of other things including marutter's PPA and I've experimented with adding those into my sources, but none has allowed me to install to completion. [Yes, when I've removed them, I've made sure to run through clean and autoclean each time, as above.]
To be clear, I am not obsessed about having the absolutely latest version of R/ I'd be happy with anything else slightly out-dated too, but I don't see any hint on the linux installation page for R what I might adjust.
(On my other machines, GalliumOS 2.1 and GalliumOS 3.0, I have installed R and RStudio, no issues. )
(This problem has now been solved as described below; I had two slightly inconsistent versions of packages. I ended up removing both and re-installed just one.)
I became convinced, after following the chain of fails on a number of the pathways, — "going down the rabbit hole", as suggested by @user535733 — that somehow two different sources appeared to have crept onto my system, each individually providing a consistent complete set of packages, but across the both mutually incompatible. An instance of that was finding gcc-8-base referring to both 8.3.0-6ubuntu1~18.04 and 8-20180414-1ubuntu2, but there were others, eventually found to be too many to resolve one at a time.
So I removed and restored the default repositories, as in, e.g., How do I restore the default repositories? through moving /etc/apt/sources.list to some safe temporary place [to be discarded later after everything was seen to work], touch-ing to create a new empty version, and then using software-properties-gtk to provide a fresh set of Ubuntu Software sources, and Updates (security and updates channels). Closed that so the system updated, and then in a terminal I ran
$ sudo apt update && sudo apt upgrade
$ sudo apt install r-base # Works cleanly!
(Many thanks to everyone who helped, but most of all to @user535733)
