New to using CLI OS.
So I tried changing the owner of a particular folder from root to my user so I can avoid errors of access denied whenever I would publish my dotnet app.
Basically, this is the folder structure.
myAppFolder
 ->myApp
   ->All forders that make the app(folders, .cs, .sln and the likes)
   ->publish
   ->README.md
When I use ls -lart on myAppFolder it says that the owner is the root. Though when I go inside and ls -lart in it some files/folders' owner is my user already. I figured that if I use 'sudo chown -R user myAppFolder' it should also change the owner of all it's subfolders because of the recursive flag. (Correct me if I'm wrong.) But when I did execute the command the ownership did not change to my user. Is there something I'm missing here? Is my understanding of the used command wrong?
EDIT: The referenced Change folder permissions and ownership is where I actually got the command I used, I just edited it to 'sudo chown -R user myAppFolder' because I was already in the folder that contained myAppfolder which is /apps.
vhie
  • 101
try this command in your terminal
sudo chown -R $USER:$USER /path/to/myAppFolder
this is duplicate of this question Change folder permissions and ownership
cmak.fr
  • 8,976
GHOST
  • 357
