I have tried just dropping the files but its not booting so how can I put the iso on the usb and its bootable to where it works. UNETBOOTIN DID NOT WORK FOR ME.
Asked
Active
Viewed 2,622 times
To make a bootable Windows USB disk on Ubuntu, I would recommend using WoeUSB. To install it, use the commands:
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt update
sudo apt install woeusb
Format your USB drive as NTFS (open your files, secondary-click on the USB drive, click "Format", and select "Type" as "NTFS").
Open WoeUSB, select the Windows ISO file, and select the USB drive. Click "Install". This might take a while. When it's finished, you should see "Installation succeeded!".
You now have a bootable Windows USB drive.
Eate
- 421
