I am trying to build KIO framework using kdesrc-build --include-dependencies on Ubuntu 18.04. Initially everything goes fine, but these 3 modules(libdbusmenu-qt ,libgpg-error, gpgme) fails to bulid and compile . I am getting errors which i am not able to clear out-
Building libdbusmenu-qt (26/36)
No source update, but the module has failed to build 5 times in a row
Source update complete for libdbusmenu-qt: no files affected
Preparing build system for libdbusmenu-qt.
Removing files in build directory for libdbusmenu-qt
Old build system cleaned, starting new build system.
Running cmake...
Compiling... failed (after 1 second)
Building libgpg-error (27/36)
Updating libgpg-error (to branch master)
Source update complete for libgpg-error: no files affected
Preparing build system for libgpg-error.
Removing files in build directory for libgpg-error
Unable to configure libgpg-error with autotools
Building gpgme (29/36)
Updating gpgme (to branch master)
Source update complete for gpgme: no files affected
Preparing build system for gpgme.
Removing files in build directory for gpgme
Unable to configure gpgme with autotools
The following modules have failed to build 3 or more times in a row:
libdbusmenu-qt,
libgpg-error,
gpgme
There is probably a local error causing this kind of consistent failure, it is recommended to verify no issues on the system.
How to rectify this problem ?
