I have a clean install of Ubuntu MATE 18.04 that I wish to install TensorFlow on with GPU support. My GPU is a Titan X.
I am following the instructions from the GPU support guide but I am unable to install the NVIDIA driver due to broken packages. Here is the command and its output:
$ sudo apt-get install --no-install-recommends nvidia-driver-410
Reading package lists... Done
Building dependency tree
nvidia-driver-410 : Depends: xserver-xorg-video-nvidia-410 (= 410.104-0ubuntu1) but it is not going to be installed
I tried resolving this by using aptitude in place of apt-get and accepting the proposed solution. However, upon reboot the system freezes at login. Since it was a clean install, I simply reinstalled the OS, and now I am back to this original problem.
How do I resolve the broken packages so I can install the driver for my GPU?
