Is it possible to dual-boot Ubuntu and SparkyLinux? If yes - Can someone help me with info how to do it?
Thanks in advance.
Yes, you can. You can follow the guide posted here to install your system: How to use manual partitioning during installation?
Follow the guide with an empty disk first, and simply leave space at the end of your disk (i.e. after creating your / partition, or /home partition if you are separating them).
After the first OS is installed, you can then proceed to install the second one at the end of the disk.
If after installing the second system the first one does not show up in grub (or grub doesn't get used at all), you can either boot from Ubuntu's live disk and install and use boot-repair - the recommended settings should do the trick - or you can use a dedicated boot-repair disk found here.
circo
  • 116
