I used the following in Home
$ sudo apt install python-pip
the output was the following
Reading package lists... Done
Building dependency tree
python-pip : Depends: python:any (< 2.8)
Depends: python:any (>= 2.7.5-5~)
Recommends: python-all-dev (>= 2.6) but it is not going to be installed
Recommends: python-setuptools but it is not going to be installed
Recommends: python-wheel but it is not going to be installed
I already tried the following without sucess
sudo apt-get clean
no special output but didn't fix the problem
sudo apt-get autoclean
sudo apt-get -f install after sudo dpkg --configure -a and then
output was : 0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
sudo apt-get -u dist-upgrade and then sudo apt-get -o Debug::pkgProblemResolver=yes dist-upgrade
which gave the output : 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
The aforementioned were some of the solutions proposed here How do I resolve unmet dependencies after adding a PPA?
Thanx!! :)
