I am using Ubuntu 19.04 with the default GNOME desktop. The Yaru theme is too quiet and I am trying to add some sound files to a new folder I created: /usr/share/sounds/MyTheme. The problem is, I am not sure what the naming convention is for the sound files to be detected for the system, and I have tried looking online with no luck. Any help would be appreciated.
You could create a folder, for example in your home directory, called MyTheme. This directory should contain another directory called stereo and a file called index.theme. The index.theme file should contain the following:
[Sound Theme]
Name=MyTheme
Directories=stereo
[stereo]
OutputProfile=stereo
Next would be, that you paste your soundfiles to the stereo folder. The sound files should be *.oga, *.ogg, or *.wav, or *.sound (not sure about that) filetype. They have to be named like you can see here: https://packages.ubuntu.com/disco/all/yaru-theme-sound/filelist
Next would be that you create a folder in you home directory called mytheme_1.0-1 with mkdir mytheme_1.0-1 and then you need some more subdirectories. You can create them with
mkdir mytheme_1.0-1/usr
mkdir mytheme_1.0-1/usr/share
mkdir mytheme_1.0-1/usr/share/sounds
Now you need to copy the directory you created first to the last subdirectory of the folder you created later with cp -r MyTheme mytheme_1.0-1/usr/share/sounds/ After that you need to create another subfolder called DEBIAN with
mkdir mytheme_1.0-1/DEBIAN
and then you need to edit a file inside of that folder with
gedit mytheme_1.0-1/DEBIAN/control
That file needs to contain something like:
Package: mytheme
Version: 1.0-1
Section: base
Priority: optional
Architecture: amd64
Depends:
Maintainer: Your Name <you@email.com>
Description: MyTheme
Just save the file and run dpkg-deb --build mytheme_1.0-1 in your home directory. Now you need to install the package you created. You can do this with sudo dpkg -i mytheme_1.0-1.deb from your home directory. At last you can choose your sound theme using the gnome-tweak-tool. If you want to uninstall the package just run sudo apt purge mytheme.
Good luck
