After running Disk Usage Analyzer on the file system, I am looking for ways to remove unneeded files on my Live USB.
  1. Firstly, is there anything I can do about the files in the casper archive? For example, I noticed that there exists a directory /rofs, which I'm sure stands for read-only file system, the one stored in the read-only casper file, so I can't removing anything in it. Specifically, I removed LibreOffice yet /rofs/usr/lib/libreoffice takes up 222 MB of precious storage, as does Thunderbird and a bunch of other things.
  2. What can I clear regarding the apt program files. /var/lib/apt/lists takes up 115 MB, and /var/cache/apt (not the archives directory) is 139 MB. The /var/cache/apt folder is made up of several ~35 MB files, and I don't know if they are all necessary:
    ubuntu@ubuntu:/var/cache/apt$ du -ah
    4.0K    ./archives/partial
    0       ./archives/lock
    28K     ./archives
    4.0K    ./typescript
    34M     ./srcpkgcache.bin
    31M     ./srcpkgcache.bin.ifDvIA
    34M     ./pkgcache.bin.3IHVIK
    32K     ./pkgcache.bin.h2Zwz7
    36M     ./pkgcache.bin
    133M    .
  3. I already clear browsing data regularly when I use chrome, so I don't think I have to deal with that much. However, I see that there are cache folders for other programs, and I wish to know if there is a safe way to remove the cache.
Generally, my question revolves around why I have only less than 300 MB on my 4.0 GB USB thumb drive when I only use it for browsing and simple development in python.
Your help is appreciated.
ladaghini
  • 800
A quick fix is to reduce the archived journals. On my LiveCD those files occupied 300M. Handy when down to 0.
sudo journalctl --vacuum-size=50M
how to clear journal
Then edit journald.conf
sudo nano /etc/systemd/journald.conf
set to desired value:
#SystemMaxUse=50M
After reboot this setting has no effect on Mint.
OneArb
  • 111
You would need to make a custom .iso to modify those files.
See : Can I build a Ubuntu ISO from a manifest?
The root file system is compressed to fit on the iso, but casper mounts the file system ro (rofs).
You can use persistence , but persistence takes up even more space (cow).
How did you make your usb ? The iso should take up only 700 Mb or so, do you have other data stored on the usb ? Persistence ?
Panther
  • 104,528
