Background: I am running a cqpweb, a corpus query interface written in PHP and connected to a mysql database, on an Apache2 webserver under Ubuntu 18.04 LTS. The Ubuntu server was set up from scratch and there are currently no manual configurations to mysql or php.
cqpweb ran happily unless it started throwing out error messages like this one:
A MySQL query did not run successfully!
Original query: LOAD DATA LOCAL INFILE '/data2/cqpweb/cach/tab_dist_fycel9oplk' INTO TABLE `db_dist_g2f3ndxf40` FIELDS ESCAPED BY '' /* from User: knappen |
Function: create_db() | 2019-Apr-25 11:23:01 */
Error # 0:
This happened overnight. Similar queries definitely worked at Apr 24 17:55 (local time, Berlin timezone) and were broken at the time given in the error message.
Question: Was there some kind of automated update or upgrade that can cause this kind of behaviour.
Additional information:
php --version
PHP 7.2.17-0ubuntu0.18.04.1 (cli) (built: Apr 18 2019 14:12:38) ( NTS )
mysql --version
mysql Ver 14.14 Distrib 5.7.25, for Linux (x86_64) using EditLine wrapper
Inspection of some relevant log files:
/var/log/dkpg.log: No entries between 2019-04-24 14:47:54 and 2019-04-26 06:26:23
/var/log/apt/history.log: No entries between 2019-04-24 14:47:54 and 2019-04-26 06:26:23
/var/log/unattended-upgrades/unattended-upgrades.log:
2019-04-25 06:24:53,776 INFO Initial blacklisted packages:
2019-04-25 06:24:53,778 INFO Initial whitelisted packages:
2019-04-25 06:24:53,778 INFO Starting unattended upgrades script
2019-04-25 06:24:53,778 INFO Allowed origins are: o=Ubuntu,a=bionic, o=Ubuntu,a=bionic-security, o=UbuntuESM,a=bionic
2019-04-25 06:24:57,138 INFO No packages found that can be upgraded unattended and no pending auto-removals
More findings:
Form /var/log/apache2/error.log:
[Thu Apr 25 06:25:03.544172 2019] [mpm_prefork:notice] [pid 1244] AH00171: Graceful restart requested, doing restart
This restart is due to a cron job executing the script /etc/cron.daily/apache2. So there could be a change affecting apache2 installed ealier on but becoming active overnight in the critical time interval.
Related question, excluding other potential resasons like size limitations: What are size limits for mysql on Ubuntu 18.04 and how can I increase them?
EDIT: Since there is a daily cron job restarting Apache2, here are some changes from history.log between 2019-04-24 06:25:00 and 2019-04-25 06:25:00
Start-Date: 2019-04-24 06:52:06
Commandline: /usr/bin/unattended-upgrade
Upgrade: distro-info-data:amd64 (0.37ubuntu0.3, 0.37ubuntu0.4)
End-Date: 2019-04-24 06:52:07
Start-Date: 2019-04-24 14:46:57
Commandline: apt-get upgrade
Requested-By: knappen (1000)
Upgrade: php7.2-common:amd64 (7.2.15-0ubuntu0.18.04.2, 7.2.17-0ubuntu0.18.04.1), php7.2-cli:amd64 (7.2.15-0ubuntu0.18.04.2, 7.2.17-0ubuntu0.18.04.1), ureadahead:amd64 (0.100.0-20, 0.100.0-21), linux-libc-dev:amd64 (4.15.0-47.50, 4.15.0-48.51), libsystemd0:amd64 (237-3ubuntu10.20, 237-3ubuntu10.21), php7.2-mysql:amd64 (7.2.15-0ubuntu0.18.04.2, 7.2.17-0ubuntu0.18.04.1), language-selector-common:amd64 (0.188.1, 0.188.2), udev:amd64 (237-3ubuntu10.20, 237-3ubuntu10.21), plymouth-theme-ubuntu-text:amd64 (0.9.3-1ubuntu7.18.04.1, 0.9.3-1ubuntu7.18.04.2), php7.2-json:amd64 (7.2.15-0ubuntu0.18.04.2, 7.2.17-0ubuntu0.18.04.1), php7.2-opcache:amd64 (7.2.15-0ubuntu0.18.04.2, 7.2.17-0ubuntu0.18.04.1), linux-signed-generic:amd64 (4.15.0.47.49, 4.15.0.48.50), libudev1:amd64 (237-3ubuntu10.20, 237-3ubuntu10.21), libplymouth4:amd64 (0.9.3-1ubuntu7.18.04.1, 0.9.3-1ubuntu7.18.04.2), python3-distupgrade:amd64 (1:18.04.30, 1:18.04.31), ubuntu-release-upgrader-core:amd64 (1:18.04.30, 1:18.04.31), systemd-sysv:amd64 (237-3ubuntu10.20, 237-3ubuntu10.21), php7.2-readline:amd64 (7.2.15-0ubuntu0.18.04.2, 7.2.17-0ubuntu0.18.04.1), libpam-systemd:amd64 (237-3ubuntu10.20, 237-3ubuntu10.21), systemd:amd64 (237-3ubuntu10.20, 237-3ubuntu10.21), libnss-systemd:amd64 (237-3ubuntu10.20, 237-3ubuntu10.21), plymouth:amd64 (0.9.3-1ubuntu7.18.04.1, 0.9.3-1ubuntu7.18.04.2), libapache2-mod-php7.2:amd64 (7.2.15-0ubuntu0.18.04.2, 7.2.17-0ubuntu0.18.04.1)
End-Date: 2019-04-24 14:47:54
