Background: I am running a cqpweb, a corpus query interface written in PHP and connected to a mysql database, on an Apache2 webserver under Ubuntu 18.04 LTS. The Ubuntu server was set up from scratch and there are currently no manual configurations to mysql or php.
cqpweb ran happily unless it started throwing out error messages like this one:
A MySQL query did not run successfully!
Original query: LOAD DATA LOCAL INFILE '/data2/cqpweb/cach/tab_dist_fycel9oplk' INTO TABLE `db_dist_g2f3ndxf40` FIELDS ESCAPED BY '' /* from User: knappen |
Function: create_db() | 2019-Apr-25 11:23:01 */
Error # 0:
This happened overnight, no updates or other changes to the system occurred. Therefore I suspect that some size limit of the database was reached and that I will have to increase it.
Question: What are some size limits for mysql databases and how can I increase them?
Additional information:
php --version
PHP 7.2.17-0ubuntu0.18.04.1 (cli) (built: Apr 18 2019 14:12:38) ( NTS )
mysql --version
mysql Ver 14.14 Distrib 5.7.25, for Linux (x86_64) using EditLine wrapper
Size of mysql:
root@corpora:/var/lib/mysql# du -h ./
23M ./mysql
676K ./sys
16G ./cqpweb
1.1M ./performance_schema
16G ./
Error log: There are no related messages in /var/log/mysql/error.log.
Running the database query manually from the mysql prompt (under the same database user as cqpweb) succeeds (to my big surprise).
EDIT: Raw disk space is not an issue—there is enough space left on the device.
EDIT2: I tried a brute force approach to the basic problem, did a backup of the data in the database using mysqldump, destroying the database, reinstalling mysql-server, restoring the database from the dump; reducing the size from 16G to 11G, but the original problem persists.
