I would like to create an alias for the move command -
trash='mv <some files> /home/$USER/.local/share/Trash/files'
How do I make this work?
I want the destination to always be the same. But I want to be able to pass the files to be moved.
charsi
  • 353
Use function instead of alias, defined in .bashrc
nano ~/.bashrc
# put inside .bashrc:
trash() {
  for item in "$@" ; do
    echo "Trashing: $item"
    mv "$item" /home/$USER/.local/share/Trash/files
  done
Then in shell prompt you can use:
$ trash file1 file2
LeonidMew
  • 2,802
You can only append arguments to an alias. Fortunately, mv allows you to do this, with the -t option
alias trash='mv -t ~/.local/share/Trash/files'
glenn jackman
  • 18,218
You can also create a bash script and run that script with an alias.
trash.sh:
#!/bin/sh
for arg in $*; do
    mv $arg /home/$USER/.local/share/Trash/files
done
exit 0
.bashrc:
alias trash="/path/to/script/trash.sh"
Cloud9Developer
  • 458
