I've written a line in .bashrc
alias untar='sudo tar –xvzf'
Now, when I use "untar" in bash I get the error:
untar filename.tar.gz
tar: invalid option -- '�' Try 'tar --help' or 'tar --usage' for more information.
However when I use the actual command instead of the alias
sudo tar –xvzf filename.tar.gz
It works fine.
I did run . ~/.bashrc, so the alias is "known" (or however you'd call it). Which is also evident form the error message which acknowledges it's a tar command. There's other aliases in bashrc which still work fine.
So, why isn't my alias working?
Your alias has a bad character, not the standard ASCII symbol (minus sign) but another one, which by some fonts is rendered as a longer dash.
This alias works for me
alias untar='sudo tar -xvf'
$ printf '-'|hexdump -C
00000000  2d                                                |-|
00000001
$ printf '–'|hexdump -C
00000000  e2 80 93                                          |...|
00000003
sudodus
  • 47,684
