How can i update to a specific version of ubuntu ? F.e. 16.04.0 to 16.04.3 instead of 16.04.6 (latest 16.04 release at this time). Is there a solution that works on 16.04 and 18.04 (18.04.0 to 18.04.1 INSTEAD to 18.04.2)?
Yes, ive seen similar questions, but none of them were answered with a way to update to a version that is NOT the latest version.
this is intended for a test environment, to test software during the different update versions of ubuntu. Start with one software install state and update it to X, where it is tested.
Andreas
  • 91
You probably already have the hardware stacks: it is basically picking the corresponding kernel when GRUB pops up. So the closest to what you want is by picking the 16/18.10 kernel and have the hardware support from 16/18.10. Mind that this only works for the hardware; the software will still be the same versions.
Some extra info:
16.04.1 = 16.04 + Hardware stack for 16.10
16.04.2 = 16.04 + Hardware stack for 17.04
18.04.1 = 18.04 + Hardware stack for  18.10
etc
and
sudo apt install --install-recommends linux-generic-hwe-18.04
will install the 18.04 hardware stack but there is no separate 18.10, 19.04 stacks as soon as the new release arrives. This will always upgrade as far as it can go so there is no method to do exactly what you want. You can check with
hwe-support-status --verbose
(only works on LTS versions).
Related:
What is hardware enablement (HWE)?
https://wiki.ubuntu.com/Kernel/LTSEnablementStack
Rinzwind
  • 309,379
