How can I remap a modified key such as CTRL-j to another key (possibly modified), while leaving the key j alone?
I am using Ubuntu 18.04.
On ubuntu, keyboard shortcuts can be managed through 'Settings Editor' and 'Keyboard'. These programs can be respectively installed by
sudo apt install xfce4-settings-editor
sudo apt install xfce4-keyboard-settings
In xfce4-keyboard-settings (the simpler program), go to the 'Application Shortcuts' tab and double-click on the shortcut that you want to edit, presumably Ctrl+J, then edit the shortcut.
You can use the remapper deamon keyd for this purpose. See this answer for installation, usage and tips.
After installation, use the config below. It makes left control activate a layer controlj while held, where every thing you press is be default modified by control (the :C), except for the key(s) remapped in the layer---in this case only j, which is remapped to Shift + j.
You can throw other modifiers on there, e.g. j = M-A-C-S-j for Meta + Alt + Control + Shift + j.
[ids]
[main]
leftcontrol = layer(controlj)
[controlj:C]
j = S-j
