I delete it & re-installed many times with different versions but the problem persists:
vboxdrv.sh: failed: Look at /var/log/vbox-setup.log to find out what went wrong.
sudo cat /var/log/vbox-setup.log
Building the main VirtualBox module.
Error building the module:
make V=1 CONFIG_MODULE_SIG= -C /lib/modules/4.4.0-145-generic/build SUBDIRS=/tmp/vbox.0 SRCROOT=/tmp/vbox.0 -j4 modules
make[1]: warning: -jN forced in submake: disabling jobserver mode.
mkdir -p /tmp/vbox.0/.tmp_versions ; rm -f /tmp/vbox.0/.tmp_versions/*
make -f ./scripts/Makefile.build obj=/tmp/vbox.0
  gcc -Wp,-MD,/tmp/vbox.0/linux/.SUPDrv-linux.o.d  -nostdinc -isystem .........
Failed versions:
  • virtualbox-5.2_5.2.26-128414_Ubuntu_xenial_amd64.deb
  • virtualbox-6.0_6.0.4-128413~Ubuntu~xenial_amd64.deb
My linux:
uname -a
Linux cent 4.4.0-145-generic #171-Ubuntu SMP Tue Mar 26 12:43:40 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.1 LTS
Release:    16.04
Codename:   xenial
Another failed retry to build the kernel:
sudo /sbin/vboxconfig
vboxdrv.sh: Stopping VirtualBox services.
vboxdrv.sh: Starting VirtualBox services.
vboxdrv.sh: Building VirtualBox kernel modules.
There were problems setting up VirtualBox.  To re-start the set-up process, run
  /sbin/vboxconfig
as root.
Any ideas?
centurian
  • 131
