I have recently installed Ubuntu 18.04.2 on my Laptop and am experiencing regular freezing, where all windows and actions freeze (can't type, press buttons, etc.) but I can (sometimes) still move my mouse pointer (but even then, it can't click anything).
Once it freezes the only thing I can do is hold the power button down and restart it. The freezing seems completely random, and has happened when doing multiple different tasks.
You can see my lshw output here https://privatebin.net/?2f77830db7565fdd#W0cP/pE0ZfEvOTYW2QDSzDZR0GfU9dDcvUz8f6CKwTc=
I have tried looking through syslog, kern.log and also looked in /var/crash (which contained nothing) and could not see anything that stood out to me (although i'm new to this, so I may be missing something obvious).
The only thing I can think of is that it has a Ryzen CPU, but even then it seems like a lot of Ryzen issues were fixed with Ubuntu 18.
I previously had the latest Kubuntu installed and that worked fine (it did occasional freeze, but it was much, much less frequently).
Whats my next step? Is there anything I can do to either find out why its crashing, or to stop it crashing?
psidex
  • 171
I have also spent a lot of time trying to find the reason for random freezes on my Ryzen5 system. No guarantee that this works for you, since there can be a lot of different reasons, but what seemed to have fixed it for me (fingers crossed) was to disable "Automatic C-State Management" in the BIOS. You'd have to look for yourself where it is and how it is named exactly in your BIOS. It's worth a try.
Sebastian
  • 1,451
On my Ryzen 5, I faced the same problem. Although later, I figured out that this is not the Ryzen related issue.
I hope this will work for you. I've faced the same problem that Ubuntu 18.04 freezes from time to time. Ubuntu 18.04 completely froze while I was coding, then sometime later the same happened when I watched a movie it was a problem that was not related to the GPU and had random occurrence. I've found this solution after hours of searching. Just run this command and restart your computer.
sudo apt install --install-recommends linux-generic-hwe-18.04 xserver-xorg-hwe-18.04
After restarting, verify that the 5.0.0.x generic was installed:
uname -a
That'll work fine.
