I am using Windows 10 and have been facing multiple issues with it. One of my friend recommended I use Linux as it's more secure and reliable, but I have some important data in my existing Windows 10 in other drives.
I can't afford an external hard disk to back up all the data, so I want to know how I can install Linux on only the C drive without affecting the other Windows drives where I have my data.
Is this possible, or should i format all the drives and then install Linux?
Zanna
  • 72,312
That's a fallacy. Windows can be as secure as any other operating system but it requires effort. Out of the box Linux is more secure but depending on the skills of the admin it can too be a security nightmare.
Windows -> VirtualBox -> Linux. But that is not going to help with your 1st statement: "Linux [is] more secure and reliable". You then still use Windows. If that Windows is not secured neither is the software installed in that Windows.
You can opt for the dual boot method where you have 2 operating systems and pick the one to start when starting your system. That means creating empty space in your Windows system. It also has a risk of deleting data you do no want deleted: at the installer you need to pick the empty space or it will erase the whole disk.
Should I format all the drives and then install Linux?
You can but ...
without affecting other drives?
is going to be impossible.
Your 1st step is to make a backup and verify you can restore your backup. All your important data needs to be on an external medium that can not be affected by your current machine anyways; otherwise you can not call the data "important". With a backup whatever you do to your software on your system it can be restored.
The minimum steps to guarantee you can still use your data:
  1. Backup personal files
  2. Install Linux as only operating system. This will delete everything on your system.
  3. Restore the files from the backup to your "Documents", "Downloads", "Pictures" directories in Linux.
I would advice against it though. You can not comfortably learn Linux this way. You should start with a dual boot or a virtual system. Where the virtual method is probably the best option since you can do this without messing with the partitions of the current system.
Zanna
  • 72,312
Rinzwind
  • 309,379
I would suggest you to follow this guide, or any guides about how to make a dual-boot.
Multi-booting is the act of installing multiple operating systems on a computer, and being able to choose which one to boot. The term dual-booting refers to the common configuration of specifically two operating systems.
Note that considering you are new about Linux I would suggest you to use Ubuntu 18.04 (LTS). You can download it using this link.
Ced
  • 853
  • 13
  • 33
