  1. In Lubuntu 18.04 in a laptop (Model Name: SATELLITE C55DT-A5244), free shows its RAM ram is 3.3G
    $ free -h
                  total        used        free      shared  buff/cache   available
    Mem:           3.3G        1.2G        444M         46M        1.7G        1.8G
    while lshw shows the RAM should be 4GiB
     *-memory
          description: System Memory
          physical id: d
          slot: System board or motherboard
        *-bank:0
             description: SODIMM DDR3 Synchronous Unbuffered (Unregistered) 533 MHz (1.9 ns)
             product: M471B5673FH0-CF8
             vendor: Samsung
             physical id: 0
             serial:
             slot: DIMM 0
             width: 64 bits
             clock: 533MHz (1.9ns)
        *-bank:1
             description: SODIMM DDR3 Synchronous Unbuffered (Unregistered) 800 MHz (1.2 ns)
             product: M471B5773CHS-CK0
             vendor: Samsung
             physical id: 1
             serial:
             slot: DIMM 1
             width: 64 bits
             clock: 800MHz (1.2ns)
    Why do the 3.3G and 4GiB differ? The difference between 4GiB i.e. 4.29497 GB, and 3.3G is 0.99GB, i.e. 990MB.
    The two RAM chips have different frequencies: 533MHz and 800MHz. Can that be a problem? What frequencies should the two RAM chips be?
  2. In another Thinkpad T400 laptop, under Lubuntu 18.04, free and lshw also don't report the same RAM size, though with difference smaller than the previous laptop: free shows 7.7G RAM, and lshw shows 8GiB RAM from two RAM chips of the same frequency. The difference between 8GiB i.e. 8.58993 GB, and 7.7G is 0.89GB, i.e. 890MB.
     *-memory
          physical id: 2b
        *-bank:0
             description: SODIMM DDR3 Synchronous 1066 MHz (0.9 ns)
             product: SUPERTALENT02
             vendor: 8634
             physical id: 0
             serial: 00000000
             slot: DIMM 1
             width: 64 bits
             clock: 1066MHz (0.9ns)
        *-bank:1
             vendor: 8634
             physical id: 1
             serial: 00000000
             slot: DIMM 2
             width: 64 bits
Thanks.
Tim
  • 26,107
In both cases, the difference is probably the amount of system RAM that's shared to the built-in graphics adapter. There is also some amount of RAM taken by the OS that doesn't show (it's usually a small amount, and varies depending on a number of factors, including kernel version and compiled-in drivers). This RAM isn't shown by free because it's not available for the OS to use at any time, but lshw is examining the hardware information, not the BIOS/OS reported RAM figures.
Zeiss Ikon
  • 5,248
