I have a System with 1.25 TB of ram the Mother board sees it , lshw see's it , but only 1.0 TB is useable, Is there a kernel Parameter I need to recognize more memory ?
It is an Asus Mother board RS700-E9 , with 2 Intel XEON Gold 6150 CPU's
[root@xtc ~]# lshw -C memory
  *-firmware
       description: BIOS
       vendor: American Megatrends Inc.
       physical id: 0
       version: 0403
       date: 07/04/2017
       capacity: 16MiB
       capabilities: pci apm upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification uefi
  *-memory
       description: System Memory
       physical id: 31
       slot: System board or motherboard
       size: 1280GiB                 <------------- memory in system
       capabilities: ecc
       configuration: errordetection=ecc
     *-bank:0
          description: DIMM DDR4 Synchronous 2400 MHz (0.4 ns)
          product: HMAA8GL7MMR4N-UH
          vendor: Hynix
          physical id: 0
          serial: 32BF004A
          slot: DIMM_A1
          width: 64 bits
          clock: 2400MHz (0.4ns)
but can only 1 TB
[root@xtc ~]# free -h
              total        used        free      shared  buff/cache   available
Mem:           1.0T         10G        994G         19M        346M        993G
Swap:          4.0G          0B        4.0G
[root@xtc ~]#
[root@xtc ~]# dmidecode -t memory
# dmidecode 3.2
Getting SMBIOS data from sysfs.
SMBIOS 3.0 present.
Handle 0x0031, DMI type 16, 23 bytes Physical Memory Array Location: System Board Or Motherboard Use: System Memory Error Correction Type: Single-bit ECC Maximum Capacity: 768 GB <---- thats Per CPU
Error Information Handle: Not Provided Number Of Devices: 6
Handle 0x0033, DMI type 17, 40 bytes Memory Device Array Handle: 0x0031 Error Information Handle: Not Provided Total Width: 72 bits Data Width: 64 bits Size: 64 GB Form Factor: DIMM Set: None Locator: DIMM_A1 Bank Locator: NODE 1 Type: DDR4 Type Detail: Synchronous Speed: 2400 MT/s Manufacturer: Hynix Serial Number: 32BF004A Asset Tag: DIMM_A1_AssetTag Part Number: HMAA8GL7MMR4N-UH Rank: 4 Configured Memory Speed: 2400 MT/s Minimum Voltage: 1.2 V Maximum Voltage: 1.2 V Configured Voltage: 1.2 V
Handle 0x0035, DMI type 17, 40 bytes Memory Device Array Handle: 0x0031 Error Information Handle: Not Provided Total Width: 72 bits Data Width: 64 bits Size: 64 GB Form Factor: DIMM Set: None Locator: DIMM_A2 Bank Locator: NODE 1 Type: DDR4 Type Detail: Synchronous Speed: 2666 MT/s Manufacturer: Micron Serial Number: 353C140B Asset Tag: DIMM_A2_AssetTag Part Number: 72ASS8G72LZ-2G6J1 Rank: 4 Configured Memory Speed: 2400 MT/s Minimum Voltage: 1.2 V Maximum Voltage: 1.2 V Configured Voltage: 1.2 V
Handle 0x0037, DMI type 17, 40 bytes Memory Device Array Handle: 0x0031 Error Information Handle: Not Provided Total Width: 72 bits Data Width: 64 bits Size: 64 GB Form Factor: DIMM Set: None Locator: DIMM_B1 Bank Locator: NODE 1 Type: DDR4 Type Detail: Synchronous Speed: 2400 MT/s Manufacturer: Hynix Serial Number: 32BF00A6 Asset Tag: DIMM_B1_AssetTag Part Number: HMAA8GL7MMR4N-UH Rank: 4 Configured Memory Speed: 2400 MT/s Minimum Voltage: 1.2 V Maximum Voltage: 1.2 V Configured Voltage: 1.2 V
Handle 0x0039, DMI type 17, 40 bytes Memory Device Array Handle: 0x0031 Error Information Handle: Not Provided Total Width: 72 bits Data Width: 64 bits Size: 64 GB Form Factor: DIMM Set: None Locator: DIMM_B2 Bank Locator: NODE 1 Type: DDR4 Type Detail: Synchronous Speed: 2666 MT/s Manufacturer: Micron Serial Number: 353C2294 Asset Tag: DIMM_B2_AssetTag Part Number: 72ASS8G72LZ-2G6J1 Rank: 4 Configured Memory Speed: 2400 MT/s Minimum Voltage: 1.2 V Maximum Voltage: 1.2 V Configured Voltage: 1.2 V
any ideas ????
****** adding the imxi -m output
 RAM: total: 1005.33 GiB used: 12.41 GiB (1.2%)
  Array-1: capacity: 768 GiB slots: 6 EC: Single-bit ECC
  Device-1: DIMM_A1 type: DDR4 size: 64 GiB speed: 2400 MT/s
  Device-2: DIMM_A2 type: DDR4 size: 64 GiB speed: spec: 2666 MT/s
  Device-3: DIMM_B1 type: DDR4 size: 64 GiB speed: 2400 MT/s
  Device-4: DIMM_B2 type: DDR4 size: 64 GiB speed: spec: 2666 MT/s
  Device-5: DIMM_C1 type: DDR4 size: 64 GiB speed: 2400 MT/s
  Device-6: DIMM_C2 type: no module installed
  Array-2: capacity: 768 GiB slots: 6 EC: Single-bit ECC
  Device-1: DIMM_D1 type: DDR4 size: 64 GiB speed: 2400 MT/s
  Device-2: DIMM_D2 type: DDR4 size: 64 GiB speed: spec: 2666 MT/s
  Device-3: DIMM_E1 type: DDR4 size: 64 GiB speed: 2400 MT/s
  Device-4: DIMM_E2 type: DDR4 size: 64 GiB speed: spec: 2666 MT/s
  Device-5: DIMM_F1 type: DDR4 size: 64 GiB speed: 2400 MT/s
  Device-6: DIMM_F2 type: no module installed
  Array-3: capacity: 768 GiB slots: 6 EC: Single-bit ECC
  Device-1: DIMM_G1 type: DDR4 size: 64 GiB speed: 2400 MT/s
  Device-2: DIMM_G2 type: DDR4 size: 64 GiB speed: spec: 2666 MT/s
  Device-3: DIMM_H1 type: DDR4 size: 64 GiB speed: 2400 MT/s
  Device-4: DIMM_H2 type: DDR4 size: 64 GiB speed: spec: 2666 MT/s
  Device-5: DIMM_J1 type: DDR4 size: 64 GiB speed: 2400 MT/s
  Device-6: DIMM_J2 type: no module installed
  Array-4: capacity: 768 GiB slots: 6 EC: Single-bit ECC
  Device-1: DIMM_K1 type: DDR4 size: 64 GiB speed: 2400 MT/s
  Device-2: DIMM_K2 type: DDR4 size: 64 GiB speed: spec: 2666 MT/s
  Device-3: DIMM_L1 type: DDR4 size: 64 GiB speed: 2400 MT/s
  Device-4: DIMM_L2 type: DDR4 size: 64 GiB speed: spec: 2666 MT/s
  Device-5: DIMM_M1 type: DDR4 size: 64 GiB speed: 2400 MT/s
  Device-6: DIMM_M2 type: no module installed
adding proc/meminfo
# cat /proc/meminfo
MemTotal:       1054167812 kB
MemFree:        1040596332 kB
MemAvailable:   1040131352 kB
Buffers:            1400 kB
Cached:          1305460 kB
SwapCached:            0 kB
Active:          1495260 kB
Inactive:         452332 kB
Active(anon):     643724 kB
Inactive(anon):    33940 kB
Active(file):     851536 kB
Inactive(file):   418392 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:      980955128 kB
SwapFree:       980955128 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:        638656 kB
Mapped:           166396 kB
Shmem:             36088 kB
Slab:             268216 kB
SReclaimable:      90680 kB
SUnreclaim:       177536 kB
KernelStack:       22864 kB
PageTables:        43764 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:    1508039032 kB
Committed_AS:    5051712 kB
VmallocTotal:   34359738367 kB
VmallocUsed:     2269720 kB
VmallocChunk:   34081574908 kB
Percpu:            97280 kB
HardwareCorrupted:     0 kB
AnonHugePages:    221184 kB
CmaTotal:              0 kB
CmaFree:               0 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
DirectMap4k:      320044 kB
DirectMap2M:     9787392 kB
DirectMap1G:    1063256064 kB
