Preface: I have search many posts already to try and answer my issue, but haven't found any that help w/ my specific issue. Searched posts found in post-script section.
I have a Lenovo Y700 with nvidia geforce gtx and Windows 10 preloaded. I installed Ubuntu 18.04.1 LTS as dual-boot. Everything was working fine for a bit until Ubuntu would not start. Now, I choose ubuntu from the GRUB Startup and get (sorry for image quality, it's a photo of the screen since I can't screenshot): Ubuntu start-up screen
The start-up screen stays like this indefinitely. So, what I'd like to do is uninstall Ubuntu and re-install.
Since I cannot work inside Ubuntu everything needs to be done in Windows, but I don't have the Windows Installation CD.
I don't want to delete important partitions and can't use GParted. Here is my Disk Management: Disk Management window
So, please advise in which partitions to delete, and any necessary steps to uninstall Ubuntu, then re-install Ubuntu 18.04.2 LTS. Thanks in advance!
P.S. I've tried this: Windows 10 corrupts Ubuntu 18.04 partitions, and get e2fsck: Cannot continue, aborting. I've reviewed this: How can I find out which partition Ubuntu is installed on? I've reviewed this: Reinstalling Ubuntu with a dual boot. Here I followed the steps to Create a bootable USB stick on Windows and tried booting Ubuntu from USB. This gets me to the same Ubuntu start-up screen image from above.
zhl
Partial answer...
For 18.04 or newer...
  • boot to a Ubuntu Live DVD/USB
  • open a terminal window
  • type sudo fdisk -l
  • identify the /dev/XXXX device name for your "Linux Filesystem"
  • type sudo fsck -f /dev/XXXX # replacing XXXX with the number you found earlier
  • repeat the fsck command if there were errors
  • type reboot
heynnema
  • 73,649
After trying all suggestions from @oldfred & @heynnema I ended up deleting Ubuntu partitions within Windows Disk Management and reinstalled Ubuntu from USB. I followed https://www.pcsuggest.com/uninstall-ubuntu-dual-boot-windows/ for uninstall, and http://www.everydaylinuxuser.com/2016/05/how-to-dual-boot-ubuntu-and-windows-10.html for reinstall. All is working well now. Many thanks to @oldfred & @heynnema for your help!
zhl
