Running sudo apt upgrade reports
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
  libieee1284-3:i386
Use 'sudo apt autoremove' to remove it.
The following packages have been kept back:
  colord
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
leading me to think that something is broken. It appears that this package depends on libsane1, but attempting to install it gives the following error message:
 libsane1 : Depends: libsane-common (= 1.0.27-1~experimental3ubuntu2) but 1.0.27+git20190324-xenial0 is to be installed
            Recommends: sane-utils (>= 1.0.27-1~experimental3ubuntu2)
Attempting to install the right version directly with sudo apt install libsane-common=1.0.27-1~experimental3ubuntu2 gives
dpkg: error processing archive /var/cache/apt/archives/libsane1_1.0.27-1~experimental3ubuntu2_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/x86_64-linux-gnu/libsane.so.1.0.27', which is also in package libsane:amd64 1.0.27+git20190324-xenial0
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
I also was going to try uninstalling and reinstalling libsane-common, but sudo apt remove libsane-common --dry-run prints
The following packages were automatically installed and are no longer required:
  colord-data libcolord-gtk1 libcolorhug2 libieee1284-3 libieee1284-3:i386 libnss-myhostname
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
  colord gnome-control-center libsane libsane-common ubuntu-desktop
0 upgraded, 0 newly installed, 5 to remove and 0 not upgraded.
Remv ubuntu-desktop [1.417]
Remv gnome-control-center [1:3.28.2-0ubuntu0.18.04.2]
Remv colord [1.2.12-1ubuntu1]
Remv libsane [1.0.27+git20190324-xenial0]
Remv libsane-common [1.0.27+git20190324-xenial0]
which seems rather dangerous, as it would uninstall ubuntu-desktop and gnome-control-center for some strange reason. Is there a way that I can fix this without potentially breaking my entire installation?
Edit: The commands sudo apt autoremove and sudo apt clean ran without errors. Running sudo apt install colord gives the error
 colord : Depends: libsane1 (>= 1.0.24) but it is not going to be installed
l k
  • 152
I eventually took a leap of faith and fixed the problem by running
sudo dpkg --purge --force-depends libsane libsane-common
to forcibly remove the offending packages without uninstalling any core Ubuntu packages, and then
sudo apt --fix-broken install
fixed everything for me.
l k
  • 152
