For Ubuntu 16.04 and 18.04 root partitions
You're likely looking for /run/initramfs/fsck.log.
An fsck of the root filesystem necessarily happens before the root filesystem has been mounted as writable, so the filesystem check occurs early in the boot process while the system is still running from the initramfs. An fsck log is written to a RAM-backed filesystem (tmpfs) that is available for writing at this time, and it continues to be available after boot at /run/initramfs/fsck.log. This is volatile storage, so fsck logs are lost once the system reboots. It would be nice if these logs were copied to non-volatile storage after the root filesystem is mounted as writable, but this does not appear to be the case.
Here's an example:
$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 238.5G 0 disk
├─sda1 8:1 0 512M 0 part /boot/efi
└─sda2 8:2 0 238G 0 part /
$ cat /run/initramfs/fsck.log
Log of fsck -C -a -V -t ext4 /dev/sda2
Fri Nov 30 22:35:21 2018
fsck from util-linux 2.31.1
[/sbin/fsck.ext4 (1) -- /dev/sda2] fsck.ext4 -a -C0 /dev/sda2
/dev/sda2: clean, 653295/15597568 files, 6658147/62383360 blocks
