I want to check my filesystem. It has to be unmounted, so I found that I should
$ sudo touch /forcefsck
$ reboot
I did that on Sat Dec 30 10:02 2017 (approx.)
After rebooting, this is what I get (pasting only the relevant info)
My partitions:
$ sudo fdisk -l
Device Boot Id Type
/dev/sda2 * 83 Linux
/dev/sda3 5 Extended
/dev/sda4 83 Linux
/dev/sda5 82 Linux swap / Solaris
/dev/sda6 83 Linux
/dev/sda7 83 Linux
Where is each one mounted (could have used other commands, I know):
$ df -h
Filesystem Mounted on
/dev/sda6 /
/dev/sda4 /mnt/old-home
/dev/sda7 /home
/dev/sda2 /boot
Last time each parittion was checked:
$ sudo tune2fs -l /dev/sda2 | grep -i check
Last checked: Sat Dec 30 10:02:48 2017
Check interval: 0 (<none>)
$ sudo tune2fs -l /dev/sda4 | grep -i check
Last checked: Thu Nov 3 17:39:51 2016
$ sudo tune2fs -l /dev/sda6 | grep -i check
Last checked: Fri Nov 4 12:08:31 2016
$ sudo tune2fs -l /dev/sda7 | grep -i check
Last checked: Sat Dec 30 10:02:04 2017
I expected /dev/sda6 (i.e., /) to be checked, but it was not.
Is that correct?
What is the correct way to check /? I think I am currently unable to boot from a Live CD/USB.
