I apologize for the vague information that was here previously. I was posting from my phone, i am now using my USB of Ubuntu i 'try' mode. Basically, I use a SSD for my install of Ubuntu 18.04. It is only 250GB and since Ubuntu is my daily driver I wanted to move my /home directory to my 1TB hdd so I would have more space for files. These are the steps I followed:
# To temporarily mount the new partition
sudo mkdir /mnt/tmp
sudo mount /dev/sda1 /mnt/tmp
# Copy HOME to the new location
sudo rsync -avx /home/ /mnt/tmp
sudo mount /dev/sda1 /home
#this is where i had an error
sudo umount /home #got message that device is busy and cannot unmount
# the guide i followed said to unmount and then use rm -rf /home/* but i used
rm -rf /dev/nvme0n1 /home/*
# I got error: this directory is not empty, the guide i used said to reboot if this happened.
#Make HOME permanent
sudo blkid
#copy UUID, then paste in fstab
sudo nano /etc/fstab
#add following line at the end
UUID=<noted number from above>     /home    ext4     defaults    0    2
#then reboot
From rereading the guide I see a mistake i made, where I just removed the UUID on the line that was already present with '/home' in it and replaced it with the UUID for the new drive.
but after that I rebooted and now my computer just goes straight to BIOS and cannot find any bootable drives.
Output of sudo fdisk -l
Disk /dev/loop0: 1.8 GiB, 1905045504 bytes, 3720792 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 91 MiB, 95408128 bytes, 186344 sectors
Disk /dev/loop2: 34.6 MiB, 36216832 bytes, 70736 sectors
Disk /dev/loop3: 140.7 MiB, 147496960 bytes, 288080 sectors
Disk /dev/loop4: 2.3 MiB, 2355200 bytes, 4600 sectors
Disk /dev/loop5: 13 MiB, 13619200 bytes, 26600 sectors
Disk /dev/loop6: 14.5 MiB, 15208448 bytes, 29704 sectors
Disk /dev/loop7: 3.7 MiB, 3878912 bytes, 7576 sectors
Disk /dev/nvme0n1: 232.9 GiB, 250059350016 bytes, 488397168 sectors
Disklabel type: gpt
Disk identifier: 611E8FFB-79C8-4D36-A5F7-F177138D442B
Device            Start       End   Sectors   Size Type
/dev/nvme0n1p1     2048    999423    997376   487M Linux swap
/dev/nvme0n1p2   999424  24436735  23437312  11.2G Linux filesystem
/dev/nvme0n1p3 24436736 488396799 463960064 221.2G Linux filesystem
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: E4025E76-690C-4779-BBBD-0996D3C7146E
/dev/sda1   2048 1953523711 1953521664 931.5G Linux filesystem
Disk /dev/sdb: 57.9 GiB, 62109253632 bytes, 121307136 sectors
Disklabel type: dos
Disk identifier: 0x65092a4c
Device     Boot Start       End   Sectors  Size Id Type
/dev/sdb1  *     2048 121307135 121305088 57.9G  c W95 FAT32 (LBA)
Disk /dev/sdc: 7.5 GiB, 8021606400 bytes, 15667200 sectors
Disklabel type: dos
Disk identifier: 0x40993ab6
/dev/sdc1  *          0 3899391 3899392  1.9G  0 Empty
/dev/sdc2       3830956 3835883    4928  2.4M ef EFI (FAT-12/16/32)
I just tried doing sudo gedit then opening the fstab file and editing it by putting the UUID of the partition with /home on it in the file where i had edited it. when i rebooted, same thing, no bootable devices.
Here is the output of Boot-Repair as requested http://paste.ubuntu.com/p/rVGCm8pYp7/ ---updated the other one was messed up because of a flashdrive that was plugged in.
I see what I did, when trying to set up my secondary harddrive for use as a data drive, I reformatted it before trying these steps. In doing so i must have formatted the EFI partition on that drive as well so UEFI boot cannot find it.
Brett Plemons
  • 89
Okay guys, I figured it out with help from rtaft. Thank you very much.
So to start, Do not format the hdd that had your windows install if you have UEFI boot....... it will make it so your computer doesnt know how to boot. This is because the default ubuntu installer will use the existing EFI to boot with rather than creating one.
So, thankfully I did a custom partitioning in my install so i had about 400mb of empty space in the start of my nvme drive for linux swap. so i just reduced the size of that to 200mb. It was then partitioned using Gparted as unformatted with bios_grub flag.
From there i just ran boot-repair recommended repair and it installed grub in that unformatted partition. And now my computer boots like normal.
Thank you all for your help.
Brett Plemons
  • 89
