Can't install. Can't uninstall. System updates now do not work. How do I fix this?
It started with apt install libreoffice and it failed.
apt --fix-broken-install fails as follows:
sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following additional packages will be installed:
libreoffice-common
The following NEW packages will be installed:
libreoffice-common
0 upgraded, 1 newly installed, 0 to remove and 6 not upgraded.
74 not fully installed or removed.
Need to get 0 B/24.7 MB of archives.
After this operation, 79.2 MB of additional disk space will be used.
Do you want to continue? [Y/n]
(Reading database ... 406426 files and directories currently installed.)
Preparing to unpack .../libreoffice-common_1%3a6.0.7-0ubuntu0.18.04.2_all.deb ...
Unpacking libreoffice-common (1:6.0.7-0ubuntu0.18.04.2) ...
dpkg: error processing archive /var/cache/apt/archives/libreoffice-common_1%3a6.0.7-0ubuntu0.18.04.2_all.deb (--unpack):
trying to overwrite '/usr/bin/soffice', which is also in package openoffice-debian-menus 4.1.3-9783
rmdir: failed to remove '/var/lib/libreoffice/share/prereg/': No such file or directory
rmdir: failed to remove '/var/lib/libreoffice/share/': No such file or directory
rmdir: failed to remove '/var/lib/libreoffice/program/': No such file or directory
rmdir: failed to remove '/var/lib/libreoffice': No such file or directory
Adding more info to original question as requested:
$ sudo apt autoremove
You might want to run 'apt --fix-broken install' to correct these.
libreoffice-core : Depends: libreoffice-common (> 1:6.0.7) but it is not installed
libreoffice-java-common : Depends: libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2) but it is not installed
libreoffice-ogltrans : Depends: libreoffice-common but it is not installed
libreoffice-report-builder : Depends: libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2) but it is not installed
libreoffice-script-provider-bsh : Depends: libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2) but it is not installed
libreoffice-script-provider-js : Depends: libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2) but it is not installed
libreoffice-script-provider-python : Depends: libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2) but it is not installed
libreoffice-style-galaxy : Depends: libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2) but it is not installed
libreoffice-style-tango : Depends: libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2) but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
$ sudo dpkg --configure -a
[sudo] password for jax:
Setting up libboost-date-time1.65.1:amd64 (1.65.1+dfsg-0ubuntu5) ...
dpkg: dependency problems prevent configuration of libreoffice-ogltrans:
libreoffice-ogltrans depends on libreoffice-common; however:
Package libreoffice-common is not installed.
dpkg: error processing package libreoffice-ogltrans (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libreoffice-style-galaxy:
libreoffice-style-galaxy depends on libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-style-galaxy (--configure):
dpkg: dependency problems prevent configuration of libreoffice-script-provider-js:
libreoffice-script-provider-js depends on libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-script-provider-js (--configure):
Setting up libraptor2-0:amd64 (2.0.14-1build1) ...
Setting up lp-solve (5.5.0.15-4build1) ...
dpkg: dependency problems prevent configuration of libreoffice-java-common:
libreoffice-java-common depends on libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-java-common (--configure):
Setting up libcmis-0.5-5v5 (0.5.1+git20160603-3build2) ...
Processing triggers for mime-support (3.60ubuntu1) ...
dpkg: dependency problems prevent configuration of libreoffice-script-provider-python:
libreoffice-script-provider-python depends on libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-script-provider-python (--configure):
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) ...
Setting up fonts-linuxlibertine (5.3.0-4) ...
dpkg: dependency problems prevent configuration of libreoffice-librelogo:
libreoffice-librelogo depends on libreoffice-script-provider-python; however:
Package libreoffice-script-provider-python is not configured yet.
dpkg: error processing package libreoffice-librelogo (--configure):
dpkg: dependency problems prevent configuration of libreoffice-wiki-publisher:
libreoffice-wiki-publisher depends on libreoffice-java-common; however:
Package libreoffice-java-common is not configured yet.
dpkg: error processing package libreoffice-wiki-publisher (--configure):
Setting up fonts-liberation2 (2.00.1-7~18.04.1) ...
dpkg: dependency problems prevent configuration of libreoffice-sdbc-hsqldb:
libreoffice-sdbc-hsqldb depends on libreoffice-java-common (>= 1:6.0.7~); however:
dpkg: error processing package libreoffice-sdbc-hsqldb (--configure):
dpkg: dependency problems prevent configuration of libreoffice-core:
libreoffice-core depends on libreoffice-common (>> 1:6.0.7); however:
dpkg: error processing package libreoffice-core (--configure):
dpkg: dependency problems prevent configuration of libreoffice-calc:
libreoffice-calc depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
Package libreoffice-core is not configured yet.
dpkg: error processing package libreoffice-calc (--configure):
Setting up fonts-crosextra-carlito (20130920-1) ...
Setting up libclucene-core1v5:amd64 (2.3.3.4+dfsg-1) ...
Setting up librevenge-0.0-0:amd64 (0.0.4-6ubuntu2) ...
Setting up libmhash2:amd64 (0.9.9.9-7) ...
Setting up libneon27-gnutls:amd64 (0.30.2-2build1) ...
Processing triggers for bamfdaemon (0.5.3+18.04.20180207.2-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Setting up libxmlsec1:amd64 (1.2.25-1build1) ...
Setting up libclucene-contribs1v5:amd64 (2.3.3.4+dfsg-1) ...
Setting up fonts-crosextra-caladea (20130214-2) ...
dpkg: dependency problems prevent configuration of python3-uno:
python3-uno depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package python3-uno (--configure):
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Setting up libabw-0.1-1:amd64 (0.1.2-1ubuntu1) ...
dpkg: dependency problems prevent configuration of libreoffice-base-drivers:
libreoffice-base-drivers depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-base-drivers (--configure):
Setting up librasqal3:amd64 (0.9.32-1build1) ...
Setting up libeot0:amd64 (0.01-5) ...
Setting up libexttextcat-data (3.4.5-1) ...
Setting up libmythes-1.2-0:amd64 (2:1.2.4-3) ...
Setting up libcdr-0.1-1:amd64 (0.1.4-1build1) ...
dpkg: dependency problems prevent configuration of libreoffice-style-tango:
libreoffice-style-tango depends on libreoffice-style-galaxy; however:
Package libreoffice-style-galaxy is not configured yet.
libreoffice-style-tango depends on libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-style-tango (--configure):
Setting up libhsqldb1.8.0-java (1.8.0.10+dfsg-8) ...
Setting up liblangtag-common (0.6.2-1) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for shared-mime-info (1.9-2) ...
dpkg: dependency problems prevent configuration of libreoffice-report-builder:
libreoffice-report-builder depends on libreoffice-core; however:
libreoffice-report-builder depends on libreoffice-java-common; however:
libreoffice-report-builder depends on libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-report-builder (--configure):
Setting up libwps-0.4-4:amd64 (0.4.8-1) ...
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) ...
dpkg: dependency problems prevent configuration of libreoffice-gtk3:
libreoffice-gtk3 depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-gtk3 (--configure):
Setting up librdf0:amd64 (1.0.17-1.1) ...
dpkg: dependency problems prevent configuration of libreoffice-script-provider-bsh:
libreoffice-script-provider-bsh depends on libreoffice-common (= 1:6.0.7-0ubuntu0.18.04.2); however:
libreoffice-script-provider-bsh depends on libreoffice-core; however:
libreoffice-script-provider-bsh depends on libreoffice-java-common; however:
dpkg: error processing package libreoffice-script-provider-bsh (--configure):
Setting up libbsh-java (2.0b4-19) ...
Setting up fonts-opensymbol (2:102.10+LibO6.0.7-0ubuntu0.18.04.2) ...
Setting up fonts-sil-gentium (20081126:1.03-2) ...
Setting up uno-libs3 (6.0.7-0ubuntu0.18.04.2) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Setting up fonts-sil-gentium-basic (1.102-1) ...
Setting up liborcus-0.13-0:amd64 (0.13.4-2) ...
Setting up libxmlsec1-nss:amd64 (1.2.25-1build1) ...
dpkg: dependency problems prevent configuration of libreoffice-gnome:
libreoffice-gnome depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
libreoffice-gnome depends on libreoffice-gtk3; however:
Package libreoffice-gtk3 is not configured yet.
dpkg: error processing package libreoffice-gnome (--configure):
Setting up libgpgmepp6:amd64 (1.10.0-1ubuntu2) ...
Processing triggers for fontconfig (2.12.6-0ubuntu2) ...
Setting up libfreehand-0.1-1 (0.1.2-2) ...
dpkg: dependency problems prevent configuration of libreoffice-nlpsolver:
libreoffice-nlpsolver depends on libreoffice-calc; however:
Package libreoffice-calc is not configured yet.
libreoffice-nlpsolver depends on libreoffice-core; however:
libreoffice-nlpsolver depends on libreoffice-java-common; however:
dpkg: error processing package libreoffice-nlpsolver (--configure):
dpkg: dependency problems prevent configuration of libreoffice-draw:
libreoffice-draw depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-draw (--configure):
dpkg: dependency problems prevent configuration of libreoffice-avmedia-backend-gstreamer:
libreoffice-avmedia-backend-gstreamer depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-avmedia-backend-gstreamer (--configure):
Setting up libmwaw-0.3-3:amd64 (0.3.13-1) ...
dpkg: dependency problems prevent configuration of libreoffice-writer:
libreoffice-writer depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-writer (--configure):
Setting up liblangtag1:amd64 (0.6.2-1) ...
dpkg: dependency problems prevent configuration of libreoffice-impress:
libreoffice-impress depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
libreoffice-impress depends on libreoffice-draw (= 1:6.0.7-0ubuntu0.18.04.2); however:
Package libreoffice-draw is not configured yet.
dpkg: error processing package libreoffice-impress (--configure):
Setting up libepubgen-0.1-1:amd64 (0.1.0-2ubuntu1) ...
Setting up libodfgen-0.1-1:amd64 (0.1.6-2) ...
Setting up libvisio-0.1-1:amd64 (0.1.6-1build1) ...
Setting up libmspub-0.1-1:amd64 (0.1.4-1) ...
Setting up libexttextcat-2.0-0:amd64 (3.4.5-1) ...
dpkg: dependency problems prevent configuration of libreoffice-base:
libreoffice-base depends on libreoffice-base-drivers (= 1:6.0.7-0ubuntu0.18.04.2); however:
Package libreoffice-base-drivers is not configured yet.
libreoffice-base depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-base (--configure):
Setting up libwpd-0.10-10:amd64 (0.10.2-2) ...
dpkg: dependency problems prevent configuration of libreoffice-math:
libreoffice-math depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-math (--configure):
Setting up libe-book-0.1-1:amd64 (0.1.3-1) ...
dpkg: dependency problems prevent configuration of libreoffice:
libreoffice depends on libreoffice-base; however:
Package libreoffice-base is not configured yet.
libreoffice depends on libreoffice-calc; however:
libreoffice depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
libreoffice depends on libreoffice-draw; however:
libreoffice depends on libreoffice-impress; however:
Package libreoffice-impress is not configured yet.
libreoffice depends on libreoffice-math; however:
Package libreoffice-math is not configured yet.
libreoffice depends on libreoffice-writer; however:
Package libreoffice-writer is not configured yet.
libreoffice depends on libreoffice-avmedia-backend-gstreamer; however:
Package libreoffice-avmedia-backend-gstreamer is not configured yet.
libreoffice depends on python3-uno (>= 4.4.0~beta2); however:
Package python3-uno is not configured yet.
dpkg: error processing package libreoffice (--configure):
dpkg: dependency problems prevent configuration of libreoffice-sdbc-postgresql:
libreoffice-sdbc-postgresql depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-sdbc-postgresql (--configure):
dpkg: dependency problems prevent configuration of libreoffice-report-builder-bin:
libreoffice-report-builder-bin depends on libreoffice-base; however:
libreoffice-report-builder-bin depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-report-builder-bin (--configure):
dpkg: dependency problems prevent configuration of libreoffice-base-core:
libreoffice-base-core depends on libreoffice-core (= 1:6.0.7-0ubuntu0.18.04.2); however:
dpkg: error processing package libreoffice-base-core (--configure):
Setting up libpagemaker-0.0-0:amd64 (0.0.4-1) ...
Setting up libetonyek-0.1-1:amd64 (0.1.7-3) ...
Setting up libwpg-0.3-3:amd64 (0.3.1-3) ...
Setting up ure (6.0.7-0ubuntu0.18.04.2) ...
libreoffice-core
libreoffice-calc
python3-uno
libreoffice-gtk3
libreoffice-gnome
libreoffice-draw
libreoffice-writer
libreoffice-impress
libreoffice-base
libreoffice-math
libreoffice
sudo apt autoclean
Del libvirt-daemon 4.0.0-1ubuntu8.7 [2,175 kB]
Del pgadmin4-common 4.2-1.pgdg18.04+1 [2,634 kB]
Del libnvidia-gl-390 390.77-0ubuntu0.18.04.2 [14.3 MB]
Del libnvidia-common-390 390.77-0ubuntu0.18.04.2 [11.4 kB]
Del nvidia-driver-390 390.77-0ubuntu0.18.04.2 [379 kB]
Del libgs9 9.26~dfsg+0-0ubuntu0.18.04.5 [2,264 kB]
Del nvidia-compute-utils-390 390.77-0ubuntu0.18.04.2 [66.6 kB]
Del libnvidia-compute-390 390.77-0ubuntu0.18.04.2 [21.0 MB]
Del libnvidia-decode-390 390.77-0ubuntu0.18.04.2 [1,186 kB]
Del libvirt-daemon-driver-storage-rbd 4.0.0-1ubuntu8.7 [15.4 kB]
Del ghostscript-x 9.26~dfsg+0-0ubuntu0.18.04.5 [42.9 kB]
Del nvidia-kernel-source-390 390.77-0ubuntu0.18.04.2 [8,443 kB]
Del libnvidia-compute-390 390.77-0ubuntu0.18.04.2 [20.6 MB]
Del libvirt-clients 4.0.0-1ubuntu8.7 [595 kB]
Del libnvidia-encode-390 390.77-0ubuntu0.18.04.2 [50.5 kB]
Del libnvidia-encode-390 390.77-0ubuntu0.18.04.2 [50.2 kB]
Del ghostscript 9.26~dfsg+0-0ubuntu0.18.04.5 [51.3 kB]
Del libnvidia-fbc1-390 390.77-0ubuntu0.18.04.2 [42.6 kB]
Del libvirt-daemon-system 4.0.0-1ubuntu8.7 [80.7 kB]
Del nvidia-kernel-common-390 390.77-0ubuntu0.18.04.2 [11.6 kB]
Del libnvidia-ifr1-390 390.77-0ubuntu0.18.04.2 [66.7 kB]
Del libnvidia-decode-390 390.77-0ubuntu0.18.04.2 [1,117 kB]
Del libgs9-common 9.26~dfsg+0-0ubuntu0.18.04.5 [5,092 kB]
Del pgadmin4 4.2-1.pgdg18.04+1 [270 kB]
Del libnvidia-gl-390 390.77-0ubuntu0.18.04.2 [14.9 MB]
Del xserver-xorg-video-nvidia-390 390.77-0ubuntu0.18.04.2 [1,614 kB]
Del libnvidia-ifr1-390 390.77-0ubuntu0.18.04.2 [59.8 kB]
Del libvirt0 4.0.0-1ubuntu8.7 [1,248 kB]
Del libnvidia-cfg1-390 390.77-0ubuntu0.18.04.2 [71.2 kB]
Del libnvidia-fbc1-390 390.77-0ubuntu0.18.04.2 [39.8 kB]
Del nvidia-utils-390 390.77-0ubuntu0.18.04.2 [324 kB]
Del nvidia-dkms-390 390.77-0ubuntu0.18.04.2 [24.2 kB]
$ sudo apt update
Get:1 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Hit:2 http://apt.postgresql.org/pub/repos/apt bionic-pgdg InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Get:4 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Get:6 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Hit:5 https://packagecloud.io/slacktechnologies/slack/debian jessie InRelease
Get:7 http://us.archive.ubuntu.com/ubuntu bionic-backports/main amd64 Packages [1,024 B]
Get:8 http://us.archive.ubuntu.com/ubuntu bionic-backports/main i386 Packages [1,024 B]
Get:9 http://us.archive.ubuntu.com/ubuntu bionic-backports/main Translation-en [448 B]
Get:10 http://us.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [557 kB]
Get:11 http://us.archive.ubuntu.com/ubuntu bionic-updates/main i386 Packages [476 kB]
Get:12 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe i386 Packages [734 kB]
Get:13 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [744 kB]
Get:14 http://us.archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 Packages [6,424 B]
Get:15 http://us.archive.ubuntu.com/ubuntu bionic-updates/multiverse i386 Packages [6,580 B]
Fetched 2,778 kB in 2s (1,288 kB/s)
6 packages can be upgraded. Run 'apt list --upgradable' to see them.
