10
Using Ubuntu 18.04.2 LTS.
sean@sean-mcmahon:~$  sudo apt-get update
Hit:1 http://security.ubuntu.com/ubuntu bionic-security InRelease
Ign:2 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:3 http://ie.archive.ubuntu.com/ubuntu bionic InRelease
Hit:4 http://ie.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:5 http://ie.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:6 http://dl.google.com/linux/chrome/deb stable Release
Ign:7 http://ppa.launchpad.net/gnome-terminator/ppa/ubuntu bionic InRelease
Err:8 http://ppa.launchpad.net/gnome-terminator/ppa/ubuntu bionic Release
  404  Not Found [IP: 91.189.95.83 80]
Reading package lists... Done
E: The repository 'http://ppa.launchpad.net/gnome-terminator/ppa/ubuntu bionic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
So update complete, now install
sean@sean-mcmahon:~$ sudo apt-get install mysql-workbench-community
Building dependency tree
E: Unable to locate package mysql-workbench-community
I am following this guide. Any ideas why it cannot locate the package?
SeanJ
  • 379
7 Answers7
19
If you want to install Mysql Workbench Just run this command in terminal
sudo apt install mysql-workbench
You are good to go with Mysql Workbench
For Ubuntu 20.04 or higher version:
sudo snap install mysql-workbench-community
Happy Ubuntu!
rhoitjadhav
  • 824
  • 14
10
the problem that all snap packages are sanboxed and need to get permission to access local files & connect to DB.
Cannot connect MySQL Workbench to MySQL server
access files
or install dbeaver which is more stable.
tabebqena
  • 231
At the time of my wrinting it seems that only a snap version is available:
Bodo
  • 53
First
sudo apt update && sudo apt upgrade
Then
The following packages were automatically installed and are no longer required:
  libreadline5 mariadb-common
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  gdal-data libaec0 libarmadillo8 ... etc.
So it looks like community should not have been in the install statement
SeanJ
  • 379
This happened to me when using the native mysql repo which is there by default.
Rather, according to the same guide referred in question, download the .deb package from https://dev.mysql.com/downloads/repo/apt/
and then after installing using the instructions you can install workbench using
assuming you didn't touched the defaults in the installation.
mr.loop
  • 227
You can install MySQL Workbench by downloading the deb file corresponding to your OS version here. Check out the archive page for older versions.
Just do sudo dpkg -i path-to-file/filename.deb. Even if there are missing dependencies, the output of this command will specify the packages that need to be installed (and you can install them with sudo apt install package-name).
Note: There are 2 deb files for every OS version - one is mysql-workbench-community (which is what you need, I guess) and the other is mysql-workbench-community-dbgsym. I think you cannot install the latter without the former.
I had this issue when trying to install from the .deb file as it would tell me that mysql-workbench-community package was missing. Then when I would try to install mysql-workbench-community package it said it was unable to locate the package. Also I installed mysql through the mysql apt repository, so here is what ended up working for me.
sudo apt --fix-broken install
After this I was able to install the mysql-workbench-community package with
sudo apt install mysql-workbench-community
Then I was able to install Mysql Workbench with
sudo dpkg -i mysql-workbench-community-version.deb
Maybe this will work for others, maybe not.
