Efax can not send a fax.
Socket running on port 9900 efax-0.9a: 17:33:54 Error: can't open serial port /dev/ttyS1: Permission denied efax-0.9a: 17:33:54 failed page /home/andy/Documents/UHC_Appeal.pdf.001 efax-0.9a: 17:33:54 finished - unrecoverable error
I tried most of the suggestions from here.
Serial port terminal > Cannot open /dev/ttyS0: Permission denied
I had to run it as a superuser.
But the fax fails.
Error: no command or response from remote
efax-0.9a: 18:31:25 opened /dev/ttyACM0
efax-0.9a: 18:31:26 using CX93001-EIS_V0.2002-V92 in class 1
efax-0.9a: 18:31:26 dialing T1-888-517-7113
efax-0.9a: 18:31:37 connected
efax-0.9a: 18:31:39 Warning: bit-reversed HDLC frame, reversing bit order
efax-0.9a: 18:31:39 received UNKNOWN
efax-0.9a: 18:31:39 The remote ID is Fax Server P1832
efax-0.9a: 18:31:39 received DIS - answering capabilities
efax-0.9a: 18:31:39 remote has no documents to send and can receive
efax-0.9a: 18:31:39 local 196lpi 14.4kbps 8.5"/215mm any 1D - - 0ms
efax-0.9a: 18:31:39 remote 196lpi 14.4kbps 8.5"/215mm any 2D ECM-64 - 0ms
efax-0.9a: 18:31:39 session 196lpi 14.4kbps 8.5"/215mm any 1D - - 0ms
efax-0.9a: 18:31:39 sent TSI - caller ID
efax-0.9a: 18:31:40 sent DCS - session format
efax-0.9a: 18:31:44 sent TCF - channel check of 2700 bytes
efax-0.9a: 18:31:46 received CFR - channel OK
efax-0.9a: 18:31:47 header:[2019-03-16 18:31 Andrew Kennedy (0000 00000) --> 1-888-517-7113 1/1]
efax-0.9a: 18:31:56 Warning: EOF before RTC
efax-0.9a: 18:31:56 sent 20+2155 lines and 16016+0 bytes, in 9 secs at 14236 bps
efax-0.9a: 18:32:09 Error: no command or response from remote
efax-0.9a: 18:31:56 sent EOP - done
efax-0.9a: 18:32:00 received EOP - done
efax-0.9a: 18:32:00 sent EOP - done
efax-0.9a: 18:32:05 received EOP - done
efax-0.9a: 18:32:05 sent EOP - done
efax-0.9a: 18:32:09 received EOP - done
efax-0.9a: 18:32:09 sent DCN - disconnect
efax-0.9a: 18:32:11 failed page /home/andy/Documents/UHC_Appeal.pdf.001
efax-0.9a: 18:32:11 finished - invalid modem response
