I have a USB network interface which I want to set the IP address and netwmask on manually. If I do that this way:
$ sudo ip addr add 10.1.1.1/24 dev eno1
I also run this:
$ nmcli dev set eno1 managed no
$ nmcli dev
DEVICE           TYPE      STATE         CONNECTION
eno1             ethernet  unmanaged     --
But then after a variable amount of time (usually less than a minute) the IP address will be lost. If I run nmcli dev again, I see that it has again become a managed interface:
$ nmcli dev
eno1             ethernet  connecting (getting IP configuration)  Wired connection 2
I've read answers like Set static IP Ubuntu which require editing a file. I don't want to make this change permanent, so how can I set a static IP via command-line only, no file editing?
fawefawef
