Well, at first it works perfect, but then it stopped. I can use a mouse, but my touchpad doesn't work. if I restart the computer then the touchpad works completely normal, but when I shutdown computer and turn on again the touchpad doesn't work.
I had a similar problem a couple of days ago where my touchpad wasn't working as it should after I suspended Ubuntu.
Try running these commands in terminal:
(If your mouse isn't working just press ctrl+alt+T to open terminal)
First:
sudo modprobe -r psmouse
Second:
sudo modprobe psmouse
If that fixes it, you can write a script that starts whenever you "resume" the computer from being suspended. I write a how-to in this thread
If the above isn't working:
Since you are using a Lenovo laptop (like I am) there might be a chance that installing Synaptics would fix it (I just prefer libinput)
There is a great tutorial on how to do it here
Basically you need to run the following in Terminal:
xinput list
And check under "Virtual Core Pointer" and see if there is an input with "Synaptics" in it's name.
If there is run:
apt list --installed
And search for xserver-xorg-input-synaptics
If it's not installed, install it by running:
sudo apt-get install xserver-xorg-input-synaptics
Then reboot and hopefully that will fix your problems!
- 495
