14
I've recently done a fresh install of Ubuntu 18.10. I've experience an issue where the scroll function is not working properly after the system has been suspended. It's sluggish and slow, kinda like if it's only registering "half the scroll".
After a restart it works perfectly again. Any ideas?
EDIT: I found a solution that restarts the touchpad automatically via a script. Posted how to as answer! :-)
mkkl
  • 495
After several tries, I managed to find a solution and made it run automatically after reading this thread. I've only tested it on Ubuntu 18.10:
Basically, restarting the touchpad with these commands fixes it:
First run:
sudo modprobe -r psmouse
Then:
sudo modprobe psmouse
But.. I didn't want to have to write those commands after every suspend. So I setup a script running the commands above automatically everytime I resume from suspend
Run commands automatically after suspend:
1) Create script with commands (open Terminal and type)
sudo touch yourscriptname.sh
This will create the file in your home folder.
2) Edit script
sudo nano yourscriptname.sh
Paste this in and save the file:
#!/bin/bash
modprobe -r psmouse && modprobe psmouse
3) Move to your "system" folder
cd /etc/systemd/system
4) Create service:
sudo touch yourservicename.service
5) Edit service:
nano yourservicename.service
Paste this in and save it afterwards
[Unit]
Description=Run user script after suspend
After=basic.target suspend.target hibernate.target
[Service]
User=root
Environment=DISPLAY=:0
ExecStart=/home/yourusername/yourscriptname.sh
[Install]
WantedBy=basic.target suspend.target hibernate.target
6) Run chmod
sudo chmod +x /home/yourusername/yourscriptname.sh
7) Then run the following commands
systemctl daemon-reload
And:
sudo systemctl enable yourservicename.service
That should fix it!
mkkl
  • 495
Thinkpad Touchpad scrolling fixed (Permanently)!!!
First, go to the path and edit grub using any editor (run command using sudo).
Using vim editor: sudo vim /etc/default/grub
or
Using gedit editor: sudo gedit /etc/default/grub
Then, replace the existing line code in grub:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash psmouse.synaptics_intertouch=0"
Then, save the file within the text editor.
Finally, update grub.
sudo update-grub
wibeasley
  • 247
just do the following
sudo gedit /lib/systemd/system-sleep/psmouse-refresh
and paste these
#!/bin/bash
$1 is the state (pre or post)-sleep
if [[ $1 == post ]]; then sudo modprobe -r usbhid sudo modprobe -r psmouse sudo modprobe psmouse sudo modprobe usbhid fi
save and done
sudofix
  • 81
Found here:
Hi, please remove psmouse.synaptics_intertouch=0 and comment out blacklist i2c_i801 in /etc/modprobe.d/blacklist.conf, and see if this helps.
That worked perfectly for my thinkpad
