I am having an issue with kde 5.9, task bar is not showing anymore. Desktop wallpaper is black. I can still open application with CTrl+F2. I tried few commands and get this:
Any idea on how to show task bar again ?
Thank in advanced
test@test:~/.config$ kstart5 plasmashell
Warning: QT_DEVICE_PIXEL_RATIO is deprecated. Instead use:
QT_AUTO_SCREEN_SCALE_FACTOR to enable platform plugin controlled per-screen factors.
QT_SCREEN_SCALE_FACTORS to set per-screen factors.
QT_SCALE_FACTOR to set the application global scale factor.
Omitting both --window and --windowclass arguments is not recommended
test@test:~/.config$ org.kde.plasmaquick: Applet preload policy set to 1
Warning: all files used by qml by the plasmoid should be in ui/. The file in the path "file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/code/LayoutManager.js" was expected at QUrl("file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/LayoutManager.js")
Warning: all files used by qml by the plasmoid should be in ui/. The file in the path "file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/code/FolderTools.js" was expected at QUrl("file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderTools.js")
trying to show an empty dialog
file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderItemDelegate.qml:300:17: QML Text: Binding loop detected for property "width"
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Both point size and pixel size set. Using pixel size.
Warning: all files used by qml by the plasmoid should be in ui/. The file in the path "file:///usr/share/plasma/plasmoids/org.kde.panel/contents/code/LayoutManager.js" was expected at QUrl("file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/LayoutManager.js")
Warning: all files used by qml by the plasmoid should be in ui/. The file in the path "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/code/uiproperties.js" was expected at QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/uiproperties.js")
libkcups: Create-Printer-Subscriptions last error: 0 successful-ok
libkcups: Get-Jobs last error: 0 successful-ok
Plasma Shell startup completed
org.kde.plasmaquick: New Applet "Application Launcher" with a weight of 13
org.kde.plasmaquick: New Applet "Digital Clock" with a weight of 37
libkcups: 5
KCrash: Attempting to start /usr/bin/plasmashell from kdeinit
sock_file=/run/user/1000/kdeinit5__0
KCrash: crashing... crashRecursionCounter = 2
KCrash: Application Name = plasmashell path = /usr/bin pid = 7409
KCrash: Arguments: /usr/bin/plasmashell
KCrash: Attempting to start /usr/lib/x86_64-linux-gnu/libexec/drkonqi from kdeinit
QSocketNotifier: Invalid socket 8 and type 'Read', disabling...
QSocketNotifier: Invalid socket 17 and type 'Read', disabling...
QSocketNotifier: Invalid socket 9 and type 'Read', disabling...
Unable to start Dr. Konqi
Re-raising signal for core dump handling.
distro: cat /proc/version
@ElvisVinicius @Linux version 4.15.0-46-generic (buildd@lgw01-amd64-038) (gcc version 7.3.0 (Ubuntu 7.3.0-16ubuntu3)) #49-Ubuntu SMP Wed Feb 6 09:33:07 UTC 2019.
test@test:~/.config$ inxi -Fxxz
System: Host: noums Kernel: 4.15.0-46-generic x86_64 bits: 64 gcc: 7.3.0
Desktop: KDE Plasma 5.12.7 (Qt 5.9.5) dm: sddm,sddm Distro: Ubuntu 18.04.2 LTS
Machine: Device: laptop System: LENOVO product: 80MK v: Lenovo YOGA 900-13ISK serial: N/A
Mobo: LENOVO model: VIUU4 v: SDK0J40709 WIN serial: N/A
UEFI [Legacy]: LENOVO v: C6CN34WW date: 10/29/2015
Chassis: type: 10 v: Lenovo YOGA 900-13ISK serial: N/A
Battery BAT1: charge: 40.9 Wh 79.1% condition: 51.7/66.0 Wh (78%) volts: 8.5/7.5
model: Simplo BASE-BAT serial: <filter>status: Charging
CPU: Dual core Intel Core i7-6500U (-MT-MCP-) arch: Skylake rev.3 cache: 4096 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10368
clock speeds: min/max: 400/3100 MHz 1: 500 MHz 2: 500 MHz 3: 500 MHz 4: 500 MHz
Graphics: Card: Intel Skylake GT2 [HD Graphics 520] bus-ID: 00:02.0 chip-ID: 8086:1916
Display Server: x11 (X.Org 1.19.6 ) drivers: modesetting (unloaded: fbdev,vesa)
Resolution: 3200x1800@60.00hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2)
version: 4.5 Mesa 18.2.2 (compat-v: 3.0) Direct Render: Yes
Audio: Card Intel Sunrise Point-LP HD Audio driver: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:9d70
Sound: Advanced Linux Sound Architecture v: k4.15.0-46-generic
Network: Card: Intel Wireless 8260 driver: iwlwifi bus-ID: 01:00.0 chip-ID: 8086:24f3
IF: wlan0 state: down mac: <filter>
Drives: HDD Total Size: 512.1GB (88.5% used)
ID-1: /dev/sda model: SAMSUNG_MZNLN512 size: 512.1GB serial: <filter> temp: 43C
Partition: ID-1: / size: 454G used: 407G (95%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 17.08GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
RAID: System: supported: N/A
No RAID devices: /proc/mdstat, md_mod kernel module present
Unused Devices: none
Sensors: System Temperatures: cpu: 50.0C mobo: 29.8C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 277 Uptime: 1:59 Memory: 3874.7/15947.5MB
Init: systemd v: 237 runlevel: 5 Gcc sys: 7.3.0 alt: 5/6
Client: Shell (bash 4.4.191 running in konsole) inxi: 2.3.56
