I use Ubuntu 16.04.5. I had decided to try Plasma 5 desktop and did this:
 sudo add-apt-repository ppa:kubuntu-ppa/backports
 sudo apt update
 sudo apt install kubuntu-desktop
I've kept lightdm during installation. After the process finished I faced several problems with Plasma 5: It loaded dramatically slow and showed several windows with error messages. Moreover it ate 70% of my RAM which is ~2.5 Gb.
I had switched to Unity in login manager and deleted Plasma:
 sudo add-apt-repository -r ppa:kubuntu-ppa/backports
 sudo apt purge kubuntu-desktop
 sudo apt autoremove
But it looks some parts of kde are still in my system: I see KDE default cursor in login manager and in some Qt applications and when I turn on my computer I see Kubuntu logo instead of Ubuntu. I can live with startup logo but appearance of KDE cursor sometimes is annoying. How to fix it?
danielleontiev
  • 385
  • 19
For your cursor issue:
Delete the package breeze-cursor-theme and it's dependencies with this command:
sudo apt purge breeze-cursor-theme --autoremove
To change the boot logo, run this command:
sudo update-alternatives --config default.plymouth
You should see a list with available logo options. Chose the one you want.
After that you can delete the kubuntu "boot logo" package with this command:
sudo apt purge plymouth-theme-kubuntu-logo --autoremove
Just a tip: With this command, you can list KDE related packages:
dpkg -l | grep -i KDE
(But be careful with deleting them.)
Dominik K
  • 306
See if this may help:
How to remove all traces of KDE installed
  • This link shows how to remove the PPA:
https://launchpad.net/~kubuntu-ppa/+archive/ubuntu/backports
sudo apt-get install ppa-purge
sudo ppa-purge kubuntu-ppa/backports
Mikemecanic
  • 141
