11
I have a HP Probook 450 g1. I want to change the touchpad two finger scroll speed. I tried some package but nothing seems to work. also the touchpad seems to be more sensitive. is there any way to control that?
A package with UI would be a big help.
slava
  • 4,085
mosharaf13
  • 243
The default libinput touchpad driver installed in recent versions of Ubuntu does not have an option to adjust the two-finger scrolling speed. You can see that from the output of xinput --list-props <id> where <id> is the device ID of your touchpad as obtained from xinput list.
However, with the HP Probook 450 G1 you are lucky as a Google search seems to indicate that it has a Synaptics touchpad. For this, an alternative driver is available with more options.
  1. Install the Synaptics driver as follows and it should already work (source):
    sudo apt install xserver-xorg-input-synaptics
  2. If it does not work yet, also follow these instructions to override the libinput touchpad driver explicitly.
  3. Configure the option Synaptics Scrolling Distance with a command like the one below. <id> is the device ID of your touchpad as obtained from xinput list, and you have to play with the values for the vertical and horizontal scrolling distance at the end of the line to find the right ones for you. If you use negative values it will give you inverted / natural scrolling.
    xinput --set-prop <id> 'Synaptics Scrolling Distance' 8 8
  4. Once you found the right values, make them permanent using a solution from here.
tanius
  • 6,610
  • 42
  • 52
If youre using libinput you can make the "steps" of the scrolling smaller therefore making the scroll overall slower with:
xinput --set-prop "YOUR TOUCHPAD" "libinput Scrolling Pixel Distance" YOUR_SPEED
Add Option "ScrollPixelDistance" "YOUR_SPEED" to your xorg conf of the Trackpad to make it permanent.
Heres the docs for some more info:
https://man.archlinux.org/man/libinput.4#SCROLL_PIXEL_DISTANCE
GMON
  • 49
A technique to gain more control in scrolling is: Without sliding your fingertips on the touchpad, "roll" your fingertips up and down.
