The scrolling of my touchpad is too fast, and I tried using this solution here (as there is no setting for changing the scrollspeed, for some reason)
I've installed the Synapsis driver using this command:
sudo apt install xserver-xorg-input-synaptics
and then used xinput list to list the devices. It looks like this:
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ SYNAPTICS Synaptics Touch Digitizer V04 Mouse id=9 [slave pointer (2)]
⎜ ↳ SYNAPTICS Synaptics Touch Digitizer V04 id=10 [slave pointer (2)]
⎜ ↳ Wacom ISDv4 EC Pen stylus id=12 [slave pointer (2)]
⎜ ↳ Synaptics TM3075-002 id=15 [slave pointer (2)]
⎜ ↳ TPPS/2 IBM TrackPoint id=16 [slave pointer (2)]
⎜ ↳ Wacom ISDv4 EC Pen eraser id=17 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ Integrated Camera: Integrated C id=11 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=13 [slave keyboard (3)]
↳ ThinkPad Extra Buttons id=14 [slave keyboard (3)]
↳ L U F T H Ü L S E N (AVRCP) id=18 [slave keyboard (3)]
My Touchpad is the ID 9, I'm pretty sure.
Then I tried to configure the scrolling setting using this command:
xinput --set-prop 9 'Synaptics Scrolling Distance' 8 8
It returned the following errror:
property 'Synaptics Scrolling Distance' doesn't exist, you need to specify its type and format
even tho this property should exist!
I then tried something else, another user suggested:
xinput --set-prop 9 "libinput Scrolling Pixel Distance" 10
and that returned nothing, and did nothing.
When I tried inputting:
it returned the following error:
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 131 (XInputExtension)
Minor opcode of failed request: 57 ()
Value in failed request: 0x153
Serial number of failed request: 21
Current serial number in output stream: 22
I then tried writing changes to /etc/X11/xinit/xinputrc which also did not work.
Ubuntu Version: 22.04.1 LTS
I'm using Ubuntu on Xorg
Laptop: Lenovo Thinkpad Yoga 12
Anybody know how to fix this?
