I have a Ubuntu app, installed on my Windows-10 machine. As far as versions are concerned, this is the result of uname -a:
Linux <username> 4.4.0-17134-Microsoft #523-Microsoft Mon Dec 31 17:49:00 PST 2018 x86_64 x86_64 x86_64 GNU/Linux
Using this Linux "emulator", as I call it, I regularly do grep, find, wc -l, sort, ..., for analysis purposes, but this sometimes generates output files in UNIX format (I'm talking about line endings).
In order to get Windows line endings, I decided to launch a unix2dos on the file, but this gave following error message:
The program 'unix2dos' is currently not installed. You can install it by typing:
sudo apt install dos2unix
In other words, my app knows that, in order to do unix2dos, the package dos2unix is needed. This looks like good news, except for the fact that I'm not able to install it:
[sudo] password for <username>:
Reading package lists... Done
Building dependency tree
E: Unable to locate package dos2unix
I have already installed packages before, so it should be a problem specific for the dos2unix package.
For your information:
- I don't have a
/var/log/messagesfile. dmesgdoesn't work:dmesg: read kernel buffer failed: Function not implemented- I have a
/var/logdirectory, but the latest file/directory modification is around a week ago. - I have a
/var/log/aptdirectory, but the latest file/directory modification is around a week ago. - I tried debugging this myself, using
strace, but this failed (strace: exec: Operation not permitted,+++ exited with 1 +++).
Edited after first comment
apt-cache policy
Package files:
100 /var/lib/dpkg/status
release a=now
500 http://security.ubuntu.com/ubuntu xenial-security/restricted amd64 Packages
release v=16.04,o=Ubuntu,a=xenial-security,n=xenial,l=Ubuntu,c=restricted,b=amd64
origin security.ubuntu.com
500 http://security.ubuntu.com/ubuntu xenial-security/main amd64 Packages
release v=16.04,o=Ubuntu,a=xenial-security,n=xenial,l=Ubuntu,c=main,b=amd64
500 http://archive.ubuntu.com/ubuntu xenial-updates/restricted amd64 Packages
release v=16.04,o=Ubuntu,a=xenial-updates,n=xenial,l=Ubuntu,c=restricted,b=amd64
origin archive.ubuntu.com
500 http://archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages
release v=16.04,o=Ubuntu,a=xenial-updates,n=xenial,l=Ubuntu,c=main,b=amd64
500 http://archive.ubuntu.com/ubuntu xenial/restricted amd64 Packages
release v=16.04,o=Ubuntu,a=xenial,n=xenial,l=Ubuntu,c=restricted,b=amd64
500 http://archive.ubuntu.com/ubuntu xenial/main amd64 Packages
release v=16.04,o=Ubuntu,a=xenial,n=xenial,l=Ubuntu,c=main,b=amd64
Pinned packages:
Does anybody have an idea?
