from here
Music Player Daemon (MPD) is a flexible, powerful, server-side
application for playing music. Through plugins and libraries it can
play a variety of sound files while being controlled by its network
protocol.
It is available in the ubuntu 18.04 repo:
sudo apt install mpd
after installing mpd create the conf file:
sudo cat /etc/mpd.conf | tee ~/.mpdconf
create the mpd dir and some files:
mkdir /home/$USER/Music/mpd
mkdir /home/$USER/Music/mpd/playlists
touch /home/$USER/Music/mpd/{mpd.log,tag_cache,pid}
edit the conf file:
nano ~/.mpdconf
and change appriopriate portions to the values here
music_directory "/home/USER/Music"
playlist_directory "/home/USER/Music/mpd/playlists"
db_file "/home/USER/Music/mpd/tag_cache"
log_file "/home/USER/Music/mpd/mpd.log"
pid_file "/home/USER/Music/mpd/pid"
state_file "/home/USER/Music/mpd/state"
sticker_file "/home/USER/Music/mpd/sticker.sql"
#user "mpd"
bind_to_address "0.0.0.0"
port "6600"
#save_absolute_paths_in_playlists "no"
#auto_update "yes"
#zeroconf_enabled "yes"
#zeroconf_name "MPD Music Player"
#password "password@read,add,control,admin"
audio_output {
type "alsa"
name "My ALSA Device"
filesystem_charset "UTF-8"
It is importtant to that the user parameter is commented else you may get errors during running.
Also replace USER with your username
Then kill mpd from running systemwide:
sudo pkill mpd
sudo systemctl disable mpd
and make it start on login:
~/.config/autostart/mpd.desktop
and paste
[Desktop Entry]
Encoding=UTF-8
Type=Application
Name=Music Player Daemon
Comment=Server for playing audio files
Exec=mpd
StartupNotify=false
Terminal=false
Hidden=false
now start the music server:
mpd
Download the android app mpdroid
Afterwards connect both android and the board to the same network. start mpddroid and enter your servers ip and mpd port (6600). Firewall ports should also be properly setup to allow the android client access
refenence:
https://help.ubuntu.com/community/MPD
