29
I performed the most recent kernel update on my Dell 5290 2-in-1 earlier today. But moments after I plug it into its docking station, the screen flickers, blanks and freezes. The only item left on the screen is the mouse pointer, and it is stuck.
If I leave the tablet not plugged in, it runs just fine. It seems to be the docking station that triggers the freeze.
That said, I can log into the tablet via ssh even with the screen frozen. So the system is still running. But if I try to reboot the tablet via the reboot command, nothing appears to happen. sudo reboot -f will reboot the system, while sudo reboot will not.
Any ideas where I should start looking to identify this problem?
Zanna
  • 72,312
Same story here, using a XPS 15 99560 and a TB16 dock.
The only solution found for now is to revert to 4.15.0-43, using the Advanced boot options in GRUB.
Link to the kernel changelog. Link to the launchpad discussion where you can follow the evolution.
EDIT : fixed in 4.15.0-45
* External monitors does not work anymore 4.15.0-44 (LP: #1813663)
    - SAUCE: Revert "drm/i915/dp: Send DPCD ON for MST before phy_up"
Kriegalex
  • 361
This problem has been solved in 4.15.0-45-generic. Running these commands can fix the issue:
sudo apt-get update
sudo apt-get dist-upgrade
Zanna
  • 72,312
Huseyin
  • 802
This kinda happens also to me, with my Surface Pro 3, when I boot it attached to the docking station.
I can boot the device, but as soon as I log in, I get a kernel bug NULL pointer deference error. Which turns the display black and locks up all input. Network is still working though.
If I boot the device and login without docking station, it works. I can attach the docking station afterwards.
I've reported my issue here: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1813796
Corben
  • 241
