To install security updates automatically I use unattended-upgrade:
$ sudo unattended-upgrade -d | tail -1
No packages found that can be upgraded unattended and no pending auto-removals
I also tried another tool called debsecan (homepage, currently on official repos) to list all packages with any vulnerability of CVE database. On a recently updated Ubuntu 18.04 LTS it returns 967 "remotely exploitable, high urgency" vulnerabilities on 220 packages (7 times more in total):
$ debsecan | grep "remotely exploitable, high urgency" | wc -l
967
$ debsecan | grep "remotely exploitable, high urgency" | col2 | uniq | wc -l
220
$ debsecan | grep -o "CVE-20[0-2][0-9]" | sort | uniq -c
3 CVE-2007
2 CVE-2008
8 CVE-2009
3 CVE-2012
14 CVE-2013
9 CVE-2014
42 CVE-2015
173 CVE-2016
948 CVE-2017
3616 CVE-2018
4158 CVE-2019
3540 CVE-2020
1 CVE-2021
- Am I missing something?
- There is any tool to check for vulnerabilities, maybe a debsecan for Ubuntu, like Red Hat's OpenSCAP (now available! See below). Any other beside OpenVAS or Nessus?
Updates
2019: Answer from someone on Ubuntu Security Team:
In Ubuntu, landscape is the preferred solution for checking security update status.
We would certainly like for someone to contribute the modifications required to get debsecan working. Here is the bug about debsecan.
Seems
debsecanread this file:curl -s https://security-tracker.debian.org/tracker/debsecan/release/1/GENERIC | zlib-flate -uncompress | lessAFAIK (please correct me) since there is no API for Ubuntu Security Advisory (USN), the data from CVE-tracking page or USN (
or maybe easier from here, everything on bazaar.launchpad.net seems removed) should be merged [into a JSON and] there.2020-05: UST2DSA
We've just finished a tool to build debsecan suitable databases from the Ubuntu CVE Tracker data.
It is open source under Apache 2.0 and it is available here: https://github.com/BBVA/ust2dsa
Using Github's CI we rebuild the databases every 6 hours for them to contain the latest vulnerability information.
If anybody want to test the result you just have to run this command in your current Ubuntu installation:
debsecan --suite $(lsb_release --codename --short) --source https://raw.githubusercontent.com/BBVA/ust2dsa/data/2021-11: Ubuntu’s OVAL data using OpenSCAP
sudo apt install libopenscap8 # Install OpenSCAP basewget https://security-metadata.canonical.com/oval/com.ubuntu.$(lsb_release -cs).usn.oval.xml.bz2 bunzip2 com.ubuntu.$(lsb_release -cs).usn.oval.xml.bz2 oscap oval eval --report report.html com.ubuntu.$(lsb_release -cs).usn.oval.xml xdg-open report.html
