I installed the xbox controller drivers (for use with an XBox One controller) using
sudo apt install xboxdrv
However when I try to start/enable the service with
sudo systemctl start xboxdrv.service
I get the following error
Failed to start xboxdrv.service: Unit xboxdrv.service not found.
Any ideas?
Qushy
  • 65
First, try to enable the service with the following command:
sudo systemctl enable xboxdrv.service
and then try starting it with:
If the service is not found, then the service needs to be created.
Make a file called "xboxdrv.service" in the /etc/systemd/system and copy/paste the following in it:
[Unit]
Description=Xbox controller driver daemon
[Service]
Type=simple
User=root
PIDFile=/var/run/xboxdrv.pid
ExecStartPre=/usr/share/ubuntu-xboxdrv/xboxdrv-pre
EnvironmentFile=/usr/share/ubuntu-xboxdrv/uxvars
ExecStart=/usr/bin/xboxdrv --daemon --silent --pid-file /var/run/xboxdrv.pid --dbus disabled $XBOXDRV_OPTIONS $PAD_OPTIONS $CONTROLLER0_OPTIONS --next-controller $PAD_OPTIONS $CONTROLLER1_OPTIONS --next-controller $PAD_OPTIONS $CONTROLLER2_OPTIONS --next-controller $PAD_OPTIONS $CONTROLLER3_OPTIONS
[Install]
WantedBy=multi-user.target
Then enable the service: sudo systemctl enable xboxdrv.service
Followed by starting the service: sudo systemctl start xboxdrv.service
Make sure the Xbox controller is connected when you start the service.
For Ubuntu 22.04:
  • Note #1: If you have followed the previous answer, first stop and then disable the xboxdrv.service before editing the existing file to fix by the following steps:
$ sudo systemctl stop xboxdrv.service
$ sudo systemctl disable xboxdrv.service
  • Note #2: Before setting up the systemctl app, make sure if you have installed correctly the xboxdrv by the steps in this website.
  1. Make a new file called "xboxdrv.service" in the directory /etc/systemd/system and copy/paste the following text in it:
[Unit]
[Service] Type=simple User=root ExecStart=/usr/bin/xboxdrv --silent
[Install] WantedBy=multi-user.target
  1. Enable the service:
$ sudo systemctl enable xboxdrv.service
  • Make sure the Xbox controller is connected before continuing the next steps.
  1. Start the service:
$ sudo systemctl start xboxdrv.service
  1. Check if xboxdrv is running by the service:
$ sudo systemctl status xboxdrv.service (Press "q" to end)
  • Note #3: If you have forgotten to connect the controller before or the controller has been disconnected by accident and you have to reconnect it, just type:
$ sudo systemctl restart xboxdrv.service
  • Note #4: If the previous command does not solve the problem to reconnect the controller, reboot the PC and try again.
  • Note #5: It's not necessary to type in Terminal sudo xboxdrv --silent if the xboxdrv is running by the service, besides it runs every time when Ubuntu boots.
