I'm new to Ubuntu and want to install it along side Windows, so I can get the hang of it.
I installed it using Wubi, I then chose to run Ubuntu from the boot menu it does then I get 2 options:
- generic and recovery.
If choose the generic version but it doesn't load up at all. Just wondering what I did wrong or whats happening. I left my PC running for an hour with the purple screen to see if it was just setting up, nothing happens.
Also I am getting error readings when trying to create a disc , with "Nero burn" and "Windows-Disc-Burner". I am trying to install 11.10 64-bit, my pc is a 64 bit one , does it matter or do i have to install a 64bit version ,
This is the error code i get after i try boot from one of the cd's I have burned and after the Ubuntu logo appears
Enter help for list of build in commands
(Initramfs) mounts: /mounting/dev/loop0 on // filesystem. squashfs failed: input/output error
can not mount /dev/loop0/ on/cdrom/casrper/filesystem.squashfson//` filesystem. squashfs
Any suggestions would be appreciated .
